Unable to do "Garuda System Maintenance"
$ garuda-inxi
  Kernel: 6.1.36-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=4bc99fd1-6a7e-4096-8fca-ccd010a3944b rw rootflags=subvol=@
    loglevel=3 ibt=off
  Type: Laptop System: Acer product: Aspire A315-56 v: V1.15
  Mobo: IL model: Sleepy_IL v: V1.15 serial: <superuser required>
    UEFI: Insyde v: 1.15 date: 07/13/2020
  ID-1: BAT1 charge: 40.2 Wh (100.0%) condition: 40.2/47.8 Wh (84.1%)
    volts: 12.2 min: 11.2 model: LGC AP18C8K type: Li-ion serial: N/A
    status: full
  Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
    gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
    family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xBA
    L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1243 high: 1300 min/max: 400/3400 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1282 2: 1193 3: 1197
    4: 1300 bogomips: 9524
  Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI
    driver: i915 v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21
    ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56
  Device-2: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 0408:a061
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Monitor-1: eDP-1 model: BOE Display 0x07cb built: 2018 res: 1920x1080
    ratio: 16:9 modes: 1920x1080
    missing.
  Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI
    driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
  API: ALSA v: k6.1.36-1-lts status: kernel-api tools: N/A
    speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
  IF-ID-1: br-3c4b6f6d3dab state: down mac: <filter>
  IF-ID-2: br-f6b403f2c30d state: down mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
  Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4
    chip-ID: 04ca:3015 class-ID: e001
  Local Storage: total: 238.47 GiB used: 198.45 GiB (83.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
    model: RBUSNS8154P3256GJ1 size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: E8FK12.3 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
    used: 198.45 GiB (83.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
  ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
  ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.55 GiB used: 950.8 MiB (12.3%)
  System Temperatures: cpu: 65.0 C mobo: N/A
  Processes: 257 Uptime: 14h 15m wakeups: 14 Memory: available: 7.55 GiB
  used: 2.73 GiB (36.1%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1815
  pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0 pm: pacman
  pkgs: 1810 libs: 435 tools: paru pm: flatpak pkgs: 5 Shell: Bash v: 5.1.16
  running-in: qterminal inxi: 3.3.27
  System install date:     2022-09-11
  Last full system update: 2023-06-30
  Relevant software:       snapper(custom) NetworkManager mkinitcpio
That happens when you use npm to install packages system-wide. Overwrite the files with sudo pacman -Syu --overwrite "*". It would be better to use npm to install packages to the users home rather than the system, since that causes issues as you already noticed.
