Unable to create KIO worker. Can not create a socket for launching a KIO worker for protocol 'file' [Solved]
Hi all. New here just started using Garuda
Of late, after a while I start gettting the error “Unable to create KIO worker. Can not create a socket for launching a KIO worker for protocol ‘file’.”
When this happens non of my folders load any files. I tried looking online but I can’t find any recent threads.
I can’t seem to find the issue here either.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_GB.UTF-8",
LC_NAME = "en_GB.UTF-8",
LC_MONETARY = "en_ZA.UTF-8",
LC_PAPER = "en_GB.UTF-8",
LC_IDENTIFICATION = "en_GB.UTF-8",
LC_TELEPHONE = "en_GB.UTF-8",
LC_MEASUREMENT = "en_ZA.UTF-8",
LC_TIME = "en_ZA.UTF-8",
LC_NUMERIC = "en_ZA.UTF-8",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Kernel: 6.5.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=679fa21c-2321-45a2-89ea-36193ba3f033 rw rootflags=subvol=@
resume=UUID=1748060a-88f7-4386-acbb-76d6e0f59924 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Portable System: Dell product: Inspiron 3521 v: A16
serial: <superuser required> Chassis: type: 8 v: A16
Mobo: Dell model: N/A serial: <superuser required> UEFI-[Legacy]: Dell
v: A16 date: 05/24/2018
ID-1: BAT1 charge: 31.1 Wh (100.0%) condition: 31.1/66.6 Wh (46.8%)
volts: 12.7 min: 11.1 model: SANYO DELL 6HY5936K type: Unknown
serial: <filter> status: full
Info: model: Intel Core i3-3217U bits: 64 type: MT MCP arch: Ivy Bridge
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1795 high: 1796 min/max: 800/1800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1795 2: 1796 3: 1796
4: 1796 bogomips: 14366
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: Realtek Integrated Webcam HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.4:5 chip-ID: 0bda:58c2
compositor: kwin_x11 driver: gpu: i915 display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x03ab built: 2012 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
device: 1 drv: swrast surfaceless: drv: crocus x11: drv: crocus
inactive: gbm,wayland
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4000 (IVB
GT2) device-ID: 8086:0166 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 4000 (IVB GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:0166 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell 7
API: ALSA v: k6.5.3-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.81 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Dell
driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 168c:0032 class-ID: 0280
Device-1: Qualcomm Atheros Bluetooth USB Host Controller driver: btusb
v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.1:16
chip-ID: 0cf3:e004 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 6 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 326.74 GiB used: 204.33 GiB (62.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9320423AS
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: LVM1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Blade
size: 28.65 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 29.97 GiB size: 29.97 GiB (100.00%) used: 9.54 GiB (31.8%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 4 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 12.1 GiB size: 12.1 GiB (100.00%)
used: 733.4 MiB (5.9%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-4: /var/log raw-size: 29.97 GiB size: 29.97 GiB (100.00%)
used: 9.54 GiB (31.8%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-5: /var/tmp raw-size: 29.97 GiB size: 29.97 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.71 GiB used: 3.29 GiB (88.5%)
ID-2: swap-2 type: partition size: 8.1 GiB used: 180 KiB (0.0%)
System Temperatures: cpu: 89.0 C mobo: N/A
Fan Speeds (rpm): cpu: 4800
Processes: 261 Uptime: 9d 5h 5m wakeups: 11 Memory: total: 4 GiB
available: 3.72 GiB used: 2.62 GiB (70.4%) Init: systemd v: 254
pm: pacman pkgs: 1314 libs: 386 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2023-10-11 ↻
Failed units:            archlinux-keyring-wkd-sync.service logrotate.service systemd-vconsole-setup.serviceperl: warning: Setting locale failed.
LANGUAGE = "",
LC_ALL = (unset),
Garuda (2.6.17-1):
LANGUAGE = "",
LC_ALL = (unset),
Garuda (2.6.17-1):
LANGUAGE = "",
LC_ALL = (unset),
Garuda (2.6.17-1):
First thing, restart, it’s KDE :slight_smile:
Thank you for gettig back to me.
Can I restart KDE without ebooting and how do I do that?
You have not rebooted since 8 days, so many things can fail.
Log out/in will not help.
And restart is named by KDE for reboot, like konsole for terminal, and so on :slight_smile:
Okay thank you
