Hi all,
Im having an issue connecting my phone to my laptop.
Im running a barebones Gnome edition, and it hasnt worked for the ~1 or 2 weeks ive had it.
On the non-barebone gnome edition i dont remember having a problem.
I have tried what is in this post KDE connect cannot find the phone
When i run lsblk with and without the phone plugged in it seems to detect something, but i cannot mount the device.
--lsblk without phone plugged in
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 931.5G 0 disk
ββsda1 8:1 0 931.5G 0 part /run/media/j/32731323-7ad4-4797-91e1-9d2dcf92bad5
zram0 254:0 0 15.5G 0 disk [SWAP]
nvme0n1 259:0 0 238.5G 0 disk
ββnvme0n1p1 259:1 0 221.4G 0 part /var/tmp
β /var/log
β /var/cache
β /srv
β /root
β /home
β /
ββnvme0n1p2 259:2 0 17G 0 part [SWAP]
---with phone plugged in:
sr0 11:0 1 1024M 0 rom
β /var/log
β /var/cache
β /srv
β /root
β /home
β /
inxi -Faz output
System: Kernel: 5.10.61-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=490014ac-6c56-48c2-b5c3-0e651e005258 rw rootflags=subvol=@ quiet splash
resume=UUID=5591859a-dac3-49f7-b945-c58a8f415c2d loglevel=3
Desktop: Budgie 10.5.3 info: budgie-panel wm: budgie-wm dm: GDM 40.1 Distro: Garuda Linux
Machine: Type: Laptop System: Micro-Star product: GP63 Leopard 8RD v: REV:1.0 serial:
Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-16P6 v: REV:1.0 serial:
UEFI-[Legacy]: American Megatrends v: E16P6IMS.107 date: 09/05/2018
Battery: ID-1: BAT1 charge: 38.9 Wh (97.5%) condition: 39.9/53.4 Wh (74.7%) volts: 11.9 min: 10.9
model: MSI Corp. MS-16P6 type: Li-ion serial: N/A status: Unknown
CPU: Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: EA cache: L2: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 52799
Speed: 4081 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 4081 2: 4035 3: 4072 4: 4078
5: 4100 6: 4081 7: 4037 8: 4101 9: 4048 10: 4049 11: 4036 12: 4087
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
conditional, RSB filling
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1c8c class-ID: 0302
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:6 chip-ID: 5986:1140
class-ID: 0e02 serial:
Display: x11 server: X.org 1.20.13 compositor: budgie-wm driver: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348
Sound Server-1: ALSA v: k5.10.61-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000
IF: wlo1 state: up mac:
Device-2: Qualcomm Atheros Killer E2400 Gigabit Ethernet vendor: Micro-Star MSI
driver: alx v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 1969:e0a1 class-ID: 0200
IF: enp3s0 state: down mac:
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: up address: see --recommends
Drives: Local Storage: total: 1.14 TiB used: 421.61 GiB (36.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-256G
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
type: SSD serial: rev: 20140000 temp: 46.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
serial: rev: SDM1 scheme: GPT
Partition: ID-1: / raw-size: 221.44 GiB size: 221.44 GiB (100.00%) used: 47.72 GiB (21.5%) fs: btrfs
ID-2: /home raw-size: 221.44 GiB size: 221.44 GiB (100.00%) used: 47.72 GiB (21.5%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /var/log raw-size: 221.44 GiB size: 221.44 GiB (100.00%) used: 47.72 GiB (21.5%)
ID-4: /var/tmp raw-size: 221.44 GiB size: 221.44 GiB (100.00%) used: 47.72 GiB (21.5%)
ID-1: swap-1 type: partition size: 17.03 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 64.0 C mobo: N/A gpu: nouveau temp: 43.0 C
Info: Processes: 320 Uptime: 11h 1m wakeups: 1 Memory: 15.48 GiB used: 3.19 GiB (20.6%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages:
pacman: 1063 lib: 317 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: alacritty
inxi: 3.3.06
Many thanks
