Everything up to date.
pamac build java-openjdk-ea-bin
Preparing...
Cloning java-openjdk-ea-bin build files...
Checking java-openjdk-ea-bin dependencies...
Choose a provider for sh:
1: bash 5.1.004-1 core
2: dashbinsh 0.1-5 chaotic-aur
Enter a number (default=1):
Resolving dependencies...
Checking inter-conflicts...
Warning: dependency cycle detected:
Warning: harfbuzz will be installed before its freetype2 dependency
To install (129):
linux-api-headers 5.8-1 (Required By: java-openjdk-ea-bin) core
tzdata 2021a-1 (Required By: java-openjdk-ea-bin) core 395.3 kB
iana-etc 20201229-1 (Required By: fakeroot) core
filesystem 2021.01.19-1 (Required By: fakeroot) core 31.1 kB
glibc 2.32-5 (Required By: java-openjdk-ea-bin) core
gcc-libs 10.2.0-4 (Required By: autoconf) core
ncurses 6.2-1 (Required By: autoconf) core
readline 8.1.0-2 (Required By: autoconf) core
bash 5.1.004-1 (Required By: autoconf) core
gmp 6.2.1-1 (Required By: binutils) core
attr 2.4.48-3 (Required By: binutils) core
acl 2.2.53-3 (Required By: binutils) core
tar 1.33-1 (Required By: libtool) core 836.6 kB
libtool 2.4.6+42+gb88cebd5-14 core
zlib 1:1.2.11-4 (Required By: binutils) core
bzip2 1.0.8-4 (Required By: binutils) core
pcre 8.44-1 (Required By: gettext) core
less 563-1 (Required By: gzip) core
gzip 1.10-3 core
gdbm 1.19-1 (Required By: autoconf) core
db 5.3.28-5 (Required By: autoconf) core
libxcrypt 4.4.17-1 (Required By: binutils) core
perl 5.32.0-3 (Required By: autoconf) core
texinfo 6.7-3 core
libunistring 0.9.10-3 (Required By: gettext) core
gc 8.0.4-4 (Required By: make) extra
libffi 3.3-4 (Required By: gettext) core
guile 2.2.6-2 (Required By: make) extra
make 4.3-3 core
libgpg-error 1.41-1 (Required By: pacman) core
libgcrypt 1.9.1-1 (Required By: pacman) core 586.5 kB
util-linux-libs 2.36.1-4 (Required By: binutils) core
e2fsprogs 1.45.6-3 (Required By: binutils) core
openssl 1.1.1.i-2 (Required By: binutils) core
libsasl 2.1.27-3 (Required By: binutils) core
libldap 2.4.56-1 (Required By: binutils) core
keyutils 1.6.3-1 (Required By: binutils) core
krb5 1.18.3-1 (Required By: binutils) core 1.4 MB
libtirpc 1.3.1-1 (Required By: binutils) core
pambase 20200721.1-2 (Required By: binutils) core
libcap-ng 0.8.2-1 (Required By: binutils) core
audit 3.0-1 (Required By: binutils) core 381.9 kB
pam 1.5.1-1 (Required By: binutils) core 581.1 kB
sudo 1.9.5.p2-1 core 1.1 MB
expat 2.2.10-2 (Required By: binutils) core
lz4 1:1.9.3-1 (Required By: binutils) core
xz 5.2.5-1 (Required By: binutils) core
zstd 1.4.8-1 (Required By: binutils) core 797.3 kB
libarchive 3.5.1-1 (Required By: binutils) core
libcap 2.47-1 (Required By: binutils) core 61.7 kB
coreutils 8.32-1 (Required By: binutils) core
findutils 4.7.0-2 core
libtasn1 4.16.0-1 (Required By: pacman) core
libp11-kit 0.23.22-1 (Required By: binutils) core
systemd-libs 247.2-1 (Required By: binutils) core
ca-certificates-utils 20181109-4 (Required By: binutils) core
ca-certificates-mozilla 3.61-1 (Required By: binutils) core 323.6 kB
ca-certificates 20181109-4 (Required By: binutils) core
libssh2 1.9.0-2 (Required By: binutils) core
libidn2 2.3.0-1 (Required By: binutils) core
libpsl 0.21.1-1 (Required By: binutils) core
libnghttp2 1.41.0-1 (Required By: binutils) core
curl 7.74.0-1 (Required By: binutils) core
npth 1.6-2 (Required By: pacman) core
libksba 1.4.0-2 (Required By: pacman) core
libassuan 2.5.4-1 (Required By: pacman) core
glib2 2.66.4-2 (Required By: gettext) core
libsecret 0.20.4-1 (Required By: pacman) core
pinentry 1.1.0-5 (Required By: pacman) core
nettle 3.7-1 (Required By: pacman) core
gnutls 3.7.0-1 (Required By: pacman) core
sqlite 3.34.1-1 (Required By: binutils) core 1.8 MB
gnupg 2.2.27-1 (Required By: pacman) core 2.5 MB
gpgme 1.15.1-1 (Required By: pacman) core
pacman-mirrorlist 20210110-1 (Required By: pacman) core
archlinux-keyring 20210110-1 (Required By: pacman) core
pacman 5.2.2-1 core
pkgconf 1.7.3-1 core
libseccomp 2.5.1-2 (Required By: file) core
file 5.39-1 core
m4 1.4.18-3 core
flex 2.6.4-3 core
sed 4.8-1 core
shadow 4.8.1-4 (Required By: fakeroot) core
util-linux 2.36.1-4 (Required By: fakeroot) core
fakeroot 1.25.3-1 core
icu 68.2-1 (Required By: gettext) core
libxml2 2.9.10-8 (Required By: gettext) extra
libcroco 0.6.13-2 (Required By: gettext) extra
gettext 0.21-1 core
groff 1.22.4-3 core
bison 3.7.2-1 core
mpfr 4.1.0-1 (Required By: gawk) core
gawk 5.1.0-1 core
libmicrohttpd 0.9.72-1 (Required By: binutils) core
libelf 0.182-1 (Required By: binutils) core
elfutils 0.182-1 (Required By: binutils) core
binutils 2.35.1-1 core
libmpc 1.2.1-1 (Required By: gcc) core
gcc 10.2.0-4 core
grep 3.6-1 core
which 2.21-5 core
patch 2.7.6-8 core
automake 1.16.2-3 core
diffutils 3.7-3 (Required By: autoconf) core
autoconf 2.70-1 core
libpng 1.6.37-3 extra
graphite 1:1.3.14-1 extra
harfbuzz 2.7.4-1 extra
freetype2 2.10.4-1 (Required By: java-openjdk-ea-bin) extra
xcb-proto 1.14.1-3 (Required By: java-openjdk-ea-bin) extra
libxdmcp 1.1.3-3 (Required By: java-openjdk-ea-bin) extra
libxau 1.0.9-3 (Required By: java-openjdk-ea-bin) extra
libxcb 1.14-1 (Required By: java-openjdk-ea-bin) extra
xorgproto 2020.1-1 (Required By: java-openjdk-ea-bin) extra
libx11 1.7.0-3 (Required By: java-openjdk-ea-bin) extra
libxext 1.3.4-3 (Required By: java-openjdk-ea-bin) extra
libxi 1.7.10-3 (Required By: java-openjdk-ea-bin) extra
libxfixes 5.0.3-4 (Required By: java-openjdk-ea-bin) extra
libxtst 1.2.3-4 (Required By: java-openjdk-ea-bin) extra
libxrender 0.9.10-4 (Required By: java-openjdk-ea-bin) extra
alsa-topology-conf 1.2.4-2 (Required By: java-openjdk-ea-bin) extra
alsa-ucm-conf 1.2.4-2 (Required By: java-openjdk-ea-bin) extra
alsa-lib 1.2.4-3 (Required By: java-openjdk-ea-bin) extra
java-environment-common 3-3 (Required By: java-openjdk-ea-bin) extra
java-runtime-common 3-3 (Required By: java-openjdk-ea-bin) extra
nspr 4.29-1 (Required By: java-openjdk-ea-bin) core
nss 3.61-1 (Required By: java-openjdk-ea-bin) core 1.6 MB
To build (1):
java-openjdk-ea-bin 16b34-1 AUR
Total download size: 12.4 MB
Total installed size: 826.9 MB
Edit build files : [e]
Apply transaction ? [e/y/N] y
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/tzdata-2020f-1-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/filesystem-2020.09.03-1-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/pam-1.5.0-2-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/krb5-1.18.2-1-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/audit-2.8.5-9-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/zstd-1.4.5-1-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/libgcrypt-1.8.7-1-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/tar-1.32-3-x86_64.pkg.tar.xz[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/sudo-1.9.4.p2-2-x86_64.pkg.tar.zst[/url]: Error 404
[url]https://mirror.rackspace.com/archlinux/core/os/x86_64/sqlite-3.34.0-1-x86_64.pkg.tar.zst[/url]: Error 404
Error: Failed to commit transaction: failed to retrieve some files
