I have previously used Garuda on my desktop PC and recently bought myself a laptop, which has successfully booted into the live environment, installed the OS and prompted me to restart. Upon restarting, I now get stuck at "Loading initial ramdisk"...
(USB contained an ISO of KDE Dr460nized Gaming Edition downloaded today)
I am able to see the garuda-inxi output if I boot into rescue, but I am not sure how to get that output into a forum post without the desktop environment. (I tried termbin but it seems there is no internet connection as it cannot resolve the host)
In the absence of the output, here are the basic specs for now:
Please let me know if any past issues immediately come to mind for those specs, or how I can go forward with grabbing some more useful diagnostic info.
I selected the option to allow proprietary drivers in the live USB's boot menu before installing, but other than that, I haven't touched anything driver-related yet. Just clicked "Install Garuda Linux" and followed the installer.
Just reinstalled with open source and was able to successfully boot into the newly installed system. However, after being prompted to install the additional non-free drivers, and doing so, I'm unable to boot again.
Instead of getting stuck at "Loading initial ramdisk...", I have a grey screen full of more text that I'm not entirely sure how to show to you without a picture. After a minute or so, this goes away and just leaves a black screen with a frozen "_". (other tty not accessible, complete lockup unfortunately)
How can I get a command line to install these kernels?
I just booted from the live USB twice to reinstall and get the kernels before installing nvidia drivers, but now even that gets stuck here and I can't install the OS again:
Try to switch to a text console with CTRL+ALT+F2.
If not working, you can boot to a text console: when you are in the grub line that you use, press button E go at the end of the line starting with linux and add a 3 at the end (with a space before...), then CTRL+x
Nevermind, it just took a lot longer than usual and went through despite being frozen. The live environment is really struggling tho, will try to install again but it keeps freezing every click
linux-mainline doesn't work and gives the same outcome, but linux-lts and linux-xanmod (the kernel I was planning to install/use anyway) work perfectly fine, boot past the grey screen and let me log in.
One thing I noticed though is that optimus manager is missing. Is optimus even preinstalled anymore, or has some kind of new solution emerged? (it's been a while, sorry)
