UFW not installed though firewall enabled
Hello, complete newbie here, recently installed garuda dr46onized gaming, and in reading the wiki, I’m supposed to set up a firewall for security/privacy. but each time i run the command
sudo systemctl enable --now ufw & ufw enable
I get the reply
Failed to enable unit: Unit ufw.service does not exist
I did some light general searching on the forum and general fireDragon engine, but have not found anything useful, maybe I’ve not searched well enough?
How can i enable ufw for my firewall?
UFW is not installed by default.
sudo pacman -S ufw
Then you can enable the service.
sudo systemctl enable --now ufw.service
Set whatever rules you want.
sudo ufw default deny
sudo ufw allow from 192.168.0.0/24
And so on. Finally, bring up the firewall.
sudo ufw enable
See also this article: Uncomplicated Firewall - ArchWiki
