Hello,
I am really enjoying this distro but I have not figured out how to get my screen to go blank after auto logoff. How do I achieve this or direct me to the wiki area where I can read this. Thank you!
Hello,
Please post the output of garuda-inxi
Can you explain more specifically what you mean by this?
What is "auto logoff"?
Thanks for the response. Maybe I should have worded my question differently:
If you are in Dragonized KDE, and you press Ctrl+Alt+L to logoff, the screen that is shown next remains on indefinitley and I'd like it to turn off, maybe after 10 min or so. INXI Below....
Kernel: 5.17.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=177f7a3d-6e6d-42b1-9c91-f92c59f6972e rw [email protected]
Type: Desktop Mobo: Micro-Star model: MAG Z490 TOMAHAWK (MS-7C80) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.A0
date: 10/19/2021
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 5023 high: 5134 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 5001 2: 5002 3: 5089
4: 5121 5: 5002 6: 4947 7: 5002 8: 5002 9: 5002 10: 4980 11: 5134
12: 5085 13: 5001 14: 5001 15: 5001 16: 5001 bogomips: 121596
vendor: Micro-Star MSI driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1
bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x285mm (26.65x11.22")
s-diag: 735mm (28.92")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Viewteck GNV29CB built: 2020
res: 2560x1080 hz: 60 dpi: 96 gamma: 1.2 size: 680x288mm (26.77x11.34")
diag: 738mm (29.1") modes: max: 2560x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 13.0.1 DRM
3.44 5.17.7-zen1-1-zen)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.17.7-zen1-1-zen running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
Device-3: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8812 class-ID: 0280
Device-1: Realtek type: USB driver: btusb v: 0.8 bus-ID: 1-1:2
chip-ID: 0bda:a725 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 11.27 GiB (1.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 42.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
used: 11.24 GiB (11.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.5 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-4: /var/log raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 97.66 GiB size: 97.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 27.8 C pch: 44.0 C mobo: N/A gpu: amdgpu
temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 195
Processes: 383 Uptime: 8h 41m wakeups: 0 Memory: 15.54 GiB
used: 4.01 GiB (25.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1488 lib: 357 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.3-2):
System install date: 2022-05-15
Last full system update: 2022-05-15 ↻
Snapshots: Snapper (maybe)
Your post was edited to add code formatting to the terminal output, which you can do by adding three tildes (~) before and after the output
like this.
Unfortunately, that screen (SDDM) doesn't follow the settings you specify in "Power Management" because those settings are assigned to a specific user. When you are on the SDDM screen, the user profile hasn't been loaded yet.
You are supposed to be able to configure this by editing a config file:
sudo micro /etc/systemd/logind.conf
Thirty or forty lines down there are these lines:
#IdleAction=ignore
#IdleActionSec=30min
If you delete the "#" and change "ignore" to "suspend" (and specify the duration you want) that is supposed to initiate suspend after the specified idle time. However, I do see there are a couple issues open here and here related to it not working for some reason. I just tried it on my machine and couldn't get it to work.
All that to say, I'm afraid I do not have the answer to your question. Hopefully someone else can chime in with a solution.
Welcome to the community!
Thank you for the tips on how to add code formatting.
And thank for trying this on your own machine! It is just as easy for me to switch off the monitor when I am done with my sessions. Maybe this is something that developers will add in future updates...
Thanks BluishHumility. You do make me feel welcomed to the community!!!
I have found using hdmi to connect to the monitor, the monitor will time out and shutdown after powering down your computer.
A vga connector does not do that.
Thanks artb!
You are in luck, I presume. Mine is using an HDMI KVM. Maybe it is due to a difference in GPU cards or displays themselves. Mine is a Radian GPU and my display is made by VIOTEK. I've not been really impressed with this monitor. DP has already died within a year! Maybe I need to go over my monitor.
Just a thought if you go into monitor timer settings and turn off sleep the monitor may cooperate and shut down the way you want. instead of say after an hour. My monitor is a wallmart 32 inch rca I got on sale. Nothing special.
Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=15449417-b8af-455f-ac34-892500896455 rw [email protected]
Desktop: GNOME v: 42.1 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Hewlett-Packard product: HP Compaq Elite 8300 SFF
v: N/A serial: <superuser required> Chassis: type: 4
Mobo: Hewlett-Packard model: 3397 serial: <superuser required>
UEFI: Hewlett-Packard v: K01 v03.06 date: 02/12/2018
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
desc: 1x6 MiB
Speed (MHz): avg: 1596 min/max: 1600/3600 scaling: driver: intel_cpufreq
governor: powersave cores: 1: 1596 2: 1596 3: 1596 4: 1596 bogomips: 25541
Type: l1tf
STIBP: disabled, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ASUSTeK driver: nvidia
v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 1 speed: 2.5 GT/s
lanes: 4 link-max: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.0
chip-ID: 10de:1287 class-ID: 0300
compositor: gnome-shell driver: X: loaded: nvidia
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 271x203mm (10.67x7.99")
s-diag: 339mm (13.33")
Monitor-1: HDMI-0 res: 1024x768 hz: 60 dpi: 63
size: 410x230mm (16.14x9.06") diag: 470mm (18.51") modes: N/A
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 2 speed: 5 GT/s lanes: 8 bus-ID: 01:00.1
chip-ID: 10de:0e0f class-ID: 0403
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: f040 bus-ID: 00:19.0 chip-ID: 8086:1502
driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 447.13 GiB used: 61.47 GiB (13.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU635 size: 447.13 GiB
serial: <filter> rev: 4c18 scheme: GPT
used: 61.47 GiB (13.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 31.3 GiB used: 2.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 42 C
Processes: 264 Uptime: 3h 33m wakeups: 0 Memory: 31.3 GiB
used: 3.64 GiB (11.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1450 pacman: 1437 lib: 371 flatpak: 13
Shell: fish v: 3.4.1 running-in: kitty inxi: 3.3.15
e[1;34mGaruda (2.6.2-1):e[0m
e[1;34m System install date:e[0m 2022-05-03
e[1;34m Last full system update:e[0m 2022-05-07 e[1;31m↻
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m No/Undetected
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
