Hello all
Here is my garuda-inxi
Kernel: 6.1.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=8a404225-49ce-4c8d-a40f-9a82f0f45d62 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 2006 date: 03/19/2021
Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2350 high: 3400 min/max: 2200/5083 boost: enabled
base/boost: 3400/5050 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 17: 3400 18: 2200 19: 3400 20: 2200
21: 2200 22: 2200 23: 2200 24: 2200 25: 3400 26: 2200 27: 2200 28: 2200
29: 3400 30: 2200 31: 2200 32: 2200 bogomips: 217180
Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] vendor: XFX
driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm)
built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 0d:00.0 chip-ID: 1002:744c
Device-2: MACROSILICON ShadowCast type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 3-1:2
chip-ID: 298f:1996 class-ID: 0300
Device-3: Microsoft Modern Webcam type: USB
driver: hid-generic,usbhid,uvcvideo bus-ID: 5-3:4 chip-ID: 045e:0840
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.7
Screen-1: 0 s-res: 6400x1440 s-dpi: 96 s-size: 1688x380mm (66.46x14.96")
s-diag: 1730mm (68.12")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: center model: AAA built: 2012
res: 1920x1080 hz: 60 dpi: 85 size: 575x323mm (22.64x12.72") modes:
Monitor-2: DP-3 mapped: DisplayPort-2 pos: right model: Asus VE228
serial: <filter> built: 2015 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: LG (GoldStar) HDR WFHD serial: <filter> built: 2020 res: 2560x1440
hz: 60 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: AMD Radeon Graphics (gfx1100
LLVM 15.0.7 DRM 3.49 6.1.11-zen1-1-zen) direct-render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 3-1:2 pcie: gen: 4
chip-ID: 298f:1996 class-ID: 0300 speed: 16 GT/s lanes: 16 bus-ID: 0d:00.1
chip-ID: 1002:ab30 class-ID: 0403
Sound API: ALSA v: k6.1.11-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2725
IF: wlp7s0 state: up mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus-ID: 6-1:2 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp15s0f3u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-153b2748496c state: down mac: <filter>
IF-ID-2: br-15ba0926c9ea state: down mac: <filter>
IF-ID-3: br-7421d839c2f0 state: down mac: <filter>
IF-ID-4: br-9cbb2be322df state: down mac: <filter>
IF-ID-5: br-a123b540d91e state: down mac: <filter>
IF-ID-6: docker0 state: down mac: <filter>
IF-ID-7: virbr0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-7.2:5 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 5.91 TiB used: 2.68 TiB (45.3%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
rev: 111110WD temp: 41.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 166d 6h cycles: 100
read-units: 4,844,744 [2.48 TB] written-units: 2,022,779 [1.03 TB]
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Crucial model: CT4000P3PSSD8
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P9CR40A temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 6d 21h cycles: 12
read-units: 1,046,794 [535 GB] written-units: 5,796,833 [2.96 TB]
model: WD10EZEX-08WN4A0 family: Blue size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: 1A02 temp: 28 C
SMART: yes state: enabled health: PASSED on: 1y 301d 5h cycles: 102
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000BX500SSD1
family: Micron Client SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 056 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 7d 11h cycles: 12
written: 511.72 GiB
ID-1: / raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
used: 18.48 GiB (4.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 1.65 TiB (45.4%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p1
maj-min: 259:4
ID-4: /var raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 372.17 GiB (40.0%) fs: btrfs block-size: 4096 B dev: /dev/sdb1
maj-min: 8:17
ID-5: /var/log raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
maj-min: 259:2
ID-6: /var/tmp raw-size: 465.47 GiB size: 465.47 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 62.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.2 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 66.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 564
Processes: 589 Uptime: 17h 47m wakeups: 0 Memory: 62.68 GiB
used: 11.18 GiB (17.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1737
libs: 539 tools: octopi,paru,yay Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: terminology inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-02-06
Last full system update: 2023-02-11
I have looked around online to see where to look for these details required for troubleshooting my desktop environment freezing while playing one particular wine game. After the lock-up everything closes and goes to the login screen. This is an improvement after refreshing with a nightly test build posted on Feb 4 2023. Prior to that, I had to hard reset the computer and boot it again. Since the graphics card shown above worked fine and I have updated and reinstalled most of the packages after setting up the nightly I do not think reinstalling with a newer installer will do the trick.
I'm trying for the first step of resolving the issue, where to look in the logs. Through googling on my phone I have looked in demesg
after the freeze and the x logs but haven't found anything that would point me to what is triggering the problem. Are there other places I can't find/didn't think of where I could look? While typing this I am tempted to see if it's a temp issue with the card. I'll be testing that while seeing if I could get some pin pointed help here!
I'm assuming the issue has to do with X, but I haven't tried installing KDE wayland on this newer install to see if the issue persists while using wayland.
