Trouble with MozillaVPN & Sway
Greetings fellow humans,
first the most important part:
  Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=4f6daea6-a2ff-4ab4-a434-889f33ac6278 rw rootflags=subvol=@
    quiet resume=UUID=217041b8-f661-43db-a316-c6f01e341459 loglevel=3 ibt=off
  Desktop: Sway v: 0.5 with: waybar tools: swayidle avail: swaylock vt: 1
    lm: greetd Distro: Garuda base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
    Megatrends LLC. v: H.M0 date: 10/13/2023
  Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 3565 min/max: 550/4550 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3565 2: 3565 3: 3565
    4: 3565 5: 3565 6: 3565 7: 3565 8: 3565 9: 3565 10: 3565 11: 3565 12: 3565
    13: 3565 14: 3565 15: 3565 16: 3565 bogomips: 108797
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
    7800 XT] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DP-3, HDMI-A-1,
    Writeback-1 bus-ID: 2f:00.0 chip-ID: 1002:747e class-ID: 0300
  Display: wayland server: Xwayland v: 24.1.6 compositor: Sway v: 0.5
    driver: gpu: amdgpu display-ID: 1
  Monitor-1: DP-2 model: M40-144 serial: <filter> built: 2021 res:
    mode: 3440x1440 hz: 60 scale: 100% (1) dpi: 95 gamma: 1.2
    size: 926x387mm (36.46x15.24") diag: 995mm (39.2") modes: max: 3440x1440
    min: 720x400
  API: Vulkan v: 1.4.304 layers: 8 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
  Info: Tools: api: vulkaninfo gpu: lact wl: kanshi, swaymsg, wdisplays
    x11: xprop,xrandr
    bus-ID: 2f:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Micro-Star MSI X570-A PRO driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487
  Device-3: Corsair HS80 RGB Wireless Gaming Receiver
    lanes: 1 mode: 1.1 bus-ID: 5-4:4 chip-ID: 1b1c:0a6b class-ID: 0300
  API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api
    vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 7.73 TiB used: 456.77 GiB (5.8%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 33.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
    fw-rev: 2B2QEXM7 temp: 27.9 C scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:8 vendor: Western Digital
    model: WD BLACK SN750 SE 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 711240WD temp: 27.9 C scheme: GPT
  ID-4: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
  ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD50NMZW-59BCBS0 size: 4.55 TiB block-size: physical: 4096 B
    logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 4800 serial: <filter> fw-rev: 4004 scheme: GPT
  ID-1: / raw-size: 862.24 GiB size: 862.24 GiB (100.00%)
    used: 27.06 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 862.24 GiB size: 862.24 GiB (100.00%)
  ID-4: /var/log raw-size: 862.24 GiB size: 862.24 GiB (100.00%)
  ID-5: /var/tmp raw-size: 862.24 GiB size: 862.24 GiB (100.00%)
  ID-1: swap-1 type: partition size: 68.98 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 62.71 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 37.1 C mobo: N/A gpu: amdgpu temp: 43.0 C
    mem: 62.0 C
  Memory: total: 64 GiB note: est. available: 62.71 GiB used: 4.54 GiB (7.2%)
  Processes: 384 Power: uptime: 21m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.07 GiB services: upowerd Init: systemd
    v: 257 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1951 libs: 512 tools: pacseek,paru Compilers:
    clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.0
    running-in: foot inxi: 3.3.37
Garuda (2.7.1-1):
  System install date:     2025-03-01
  Last full system update: 2025-03-02 ↻
So I’m using Sway with MozillaVPN right now. I have used MozillaVPN before with Fedora and before that with Garuda Gnome and in both cases it worked (sometimes better, sometimes worse) but this error I’m having now I never had (previous errors were more like “program won’t start” or "program won’t compile etc).
This is nmcli without the VPN:
enp39s0: verbunden to Kabelgebundene Verbindung 1
        "Realtek RTL8111/8168/8211/8411"
        ethernet (r8169), 00:D8:61:9C:FD:B4, hw, mtu 1500
        ip4-Vorgabe, ip6-Vorgabe
        inet4 192.168.0.11/24
        route4 192.168.0.0/24 metric 100
        route4 default via 192.168.0.1 metric 100
        inet6 2a02:8109:1b10:ac00::e197/128
        inet6 2a02:8109:1b10:ac00:866e:727b:dd6b:2211/64
        inet6 fe80::bffd:e19f:dd06:da68/64
        route6 2a02:8109:1b10:ac00::e197/128 metric 100
        route6 fe80::/64 metric 1024
        route6 2a02:8109:1b10:ac00::/64 metric 100
        route6 2a02:8109:1b10:ac00::/62 via fe80::eea9:40ff:fe78:3d71 metric 100
        route6 default via fe80::eea9:40ff:fe78:3d71 metric 100
lo: nicht verwaltet
        "lo"
        loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
DNS configuration:
        servers: 88.134.228.225 88.134.228.161
        interface: enp39s0
        servers: 2a02:8100:c0:239::4:1101 2a02:8100:c0:231::4:1101
        interface: enp39s0
And this is nmclie with the VPN:
moz0: verbunden (extern) to moz0
        "moz0"
        wireguard, sw, mtu 1420
        inet4 10.135.93.43/32
        route4 10.64.0.1/32 metric 0
        route4 10.124.0.0/20 metric 0
        route4 default metric 0
        inet6 fc00:bbbb:bbbb:bb01:d:0:7:5d2b/64
        route6 fc00:bbbb:bbbb:bb01::/64 metric 256
        route6 fc00:bbbb:bbbb:bb01::1/128 metric 1024
        route6 default metric 1024
lo: nicht verwaltet
        "lo"
DNS configuration:
        interface: enp39s0
        interface: enp39s0
I know little of this, but looks fine to me. Unfortunately, it does not work. It can be enabled normally, but then I do not have internet anymore. It just doesn’t get through, nothing loads, over no program whatsoever. I thought maybe something wrong with the DNS or smth?
I was hoping someone who understands more of this, so more than nothing at all, might have some idea as to what could be the problem here.
Other than that, Sway looks great! Really nicely build.
Edit: Alright, it seems to be a general problem with the AUR-package. I just tried it on my laptop (running “pure” Arch Linux with Plasma) and the same problem occurs there. It occurs with the mozillavpn, mozillavpn-git and mozillavpn-bin package. Hmm…
First → reboot
Garuda Assistent → DNS = default ?
You use a firewall ?
Which Router you have and which version (mozillavpn) you use “standard” , “bin” or git ?
And one question why you spend money for a app ?
There are free alternatives and of course better apps for money. (my mind)
No change. DNS is default. No firewall activated. I tried all three mozillavpn-versions, all show the same behavior. Router is some Vodafone-cable-router. It works fine with Android btw.
Was mostly to support Mozilla as the last free alternative for a browser. But since I got it I use it quite frequently, too.
I put the question here, maybe someone else has the same problem.
It may not help much, but have you tested the versions from the chaotic-aur?
yeah, unfortunately doesn’t work.
It’s probably a mozillavpn-problem anyway and has nothing to do with Garuda, so I’ll try my luck in the AUR discussion. :wink: Thanks for the replies guys!
