I have set the monitor in the “Display and Monitor” section in the system settings. However, it won’t make the change from my second monitor. I have worked with ChatGpt and Claude to search through Xorg, Wayland, Xandr, KDE Plasma, SDDM, and Nvidia settings. The issue still persists. Everything shows that the monitor I want as primary is set, however, the second monitor stays the same.
This is a fresh install.
I have searched through the forum and could find nothing regarding this issue
Kernel: 6.13.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: tsc avail: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=24f188e2-e420-43db-a847-e9121eda4356 rw rootflags=subvol=@ quiet resume=UUID=471a61d2-7be2-4e1a-83c8-9a81e6dde7c0 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.12.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO v: Rev X.0x serial: <superuser required> part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 3003 date: 12/04/2020
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2 smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2222 min/max: 550/4672 boost: enabled scaling: driver: amd-pstate-epp governor: powersave cores: 1: 2222 2: 2222 3: 2222 4: 2222 5: 2222 6: 2222 7: 2222 8: 2222 9: 2222 10: 2222 11: 2222 12: 2222 13: 2222 14: 2222 15: 2222 16: 2222 17: 2222 18: 2222 19: 2222 20: 2222 21: 2222 22: 2222 23: 2222 24: 2222 bogomips: 182061
Device-1: NVIDIA TU104 [GeForce RTX 2080 SUPER] vendor: Micro-Star MSI driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-1,HDMI-A-1 empty: DP-2,DP-3,Unknown-2 bus-ID: 09:00.0 chip-ID: 10de:1e81 class-ID: 0300
Device-2: Logitech Webcam Pro 9000 driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2 chip-ID: 046d:0809 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch d-rect: 3840x1080 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: Samsung LC27RG50 serial: <filter> built: 2019 res: mode: 1920x1080 hz: 240 scale: 100% (1) dpi: 92 gamma: 1.2 size: 532x304mm (20.94x11.97") diag: 613mm (24.1") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 pos: right model: Samsung SyncMaster serial: <filter> built: 2011 res: mode: 1920x1080 hz: 60 scale: 135% (1.35) to: 1422x800 dpi: 305 gamma: 1.2 size: 160x90mm (6.3x3.54") diag: 184mm (7.2") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080 SUPER/PCIe/SSE2 memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 5 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 2080 SUPER driver: N/A device-ID: 10de:1e81 surfaces: xcb,xlib,wayland
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor gpu: corectrl, nvidia-settings, nvidia-smi wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA TU104 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 09:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Razer USA BlackShark V2 Pro driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 1532:0528 class-ID: 0300
Device-4: Logitech Webcam Pro 9000 driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1:2 chip-ID: 046d:0809 class-ID: 0102 serial: <filter>
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A Server-1: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8125 class-ID: 0200
Device-2: Intel 82574L Gigabit Network driver: e1000e v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 8086:10d3 class-ID: 0200
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
Local Storage: total: 6.37 TiB used: 19.1 GiB (0.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD1502FAEX-007BA0 size: 1.36 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD1502FAEX-007BA0 size: 1.36 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1D05 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital model: WD10EADS-11M2B1 size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.75 scheme: MBR
ID-6: /dev/sdf maj-min: 8:80 vendor: Western Digital model: WD20EARX-32PASB0 size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 2021 scheme: MBR
ID-1: / raw-size: 431.09 GiB size: 431.09 GiB (100.00%) used: 19.1 GiB (4.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 431.09 GiB size: 431.09 GiB (100.00%) used: 19.1 GiB (4.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 431.09 GiB size: 431.09 GiB (100.00%) used: 19.1 GiB (4.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 431.09 GiB size: 431.09 GiB (100.00%) used: 19.1 GiB (4.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 31.25 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24 dev: /dev/zram0
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 50.0 C mobo: 45.0 C Fan Speeds (rpm): cpu: 0
Memory: total: 32 GiB available: 31.25 GiB used: 3.57 GiB (11.4%)
Processes: 457 Power: uptime: 17m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical tool: systemctl
Packages: 1817 pm: pacman pkgs: 1810 libs: 558 tools: octopi,paru pm: flatpak pkgs: 7 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date: 2025-03-25
Last full system update: 2025-03-26
