ystem
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=d84d1289-1918-4cb8-b260-dc86d66875da rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
Type: Desktop System: Micro-Star product: MS-7A38 v: 2.0
Mobo: Micro-Star model: B350M PRO-VDH (MS-7A38) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.E0
date: 09/21/2018
Device-1: gip0.0 model: Microsoft X-Box One pad serial: N/A charge: 50%
(should be ignored) rechargeable: yes status: not charging
Info: model: AMD Ryzen 5 1400 bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001137
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3385 high: 3400 min/max: N/A cores: 1: 3400 2: 3400
3: 3399 4: 3393 5: 3385 6: 3400 7: 3398 8: 3310 bogomips: 54401
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: eVga.com.
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 1f:00.0 chip-ID: 10de:1c02 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel bus-ID: 3-3.3:9 v: kernel chip-ID: 1532:0521 pcie:
class-ID: 0300 gen: 3 serial: <filter> speed: 8 GT/s lanes: 16
bus-ID: 1f:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 21:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Razer USA Kraken Kitty Edition type: USB
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 1b:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp27s0 state: down mac: <filter>
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 1d:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp29s0 state: up mac: <filter>
Local Storage: total: 1.02 TiB used: 871.12 GiB (83.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power model: SPCC Solid State
Disk size: 111.79 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 21.1 scheme: GPT
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 66.41 GiB
(59.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 592 KiB
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 66.41
GiB (59.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 66.41
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%) used: 66.41
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: 42.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1906 fan-3: 1227 fan-4: 866 fan-5: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.25
Processes: 304 Uptime: 3h 25m wakeups: 633 Memory: 15.57 GiB used: 5.68 GiB
(36.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 2229
libs: 649 tools: pacaur,pamac,paru,yay Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-10-12
Last full system update: 2022-10-12
So I'm building my new pc tomorrow and I was wondering how I would go about transferring my current data and os to it. It will be to a new drive as well. Getting a newer ryzen cpu and amd gpu if that matters. I believe I've seen some programs capable of moving data to new drive but I've never had to change drives to entire new pc before so that is my main issue, if it even is one.
