I am not able to click on anything using my track pad can anyone suggest me what to do????
This is incredibly vague. Can you be more specific?
Yea, it doesn't work out of the Box! Can you be more specific? IT DOESN'T WORK!
Welcome to Garuda.
We prefer our users refrain from necrobumping old technical help threads. if you require assistance, It would be best for you to open your own help request thread. Be sure to provide your garuda-inxi
output on your opening post as we will require your system specs to be able to assist you.
However, if you search the forum thoroughly, you will likely find the answer to your issue as this topic has been covered many times in the past.
Good luck.
