Hi -
for clarity i am a Linux new user
Today I installed Garuda Dragon onto an older Lenova Yoga with touchscreen. All works well as far as i can tell when i am in laptop mode however when i connect with HDMI to my Samsung UHD monitor and then try to use touchscreen on the Lenovo, the focus goes directly to the monitor screen - and moving my finger on the screen of the lenovo moves and controls the cursor on the monitor although its a bit erratic- no way to get focus back to the Lenovo without using the Enovo trackpad or external mouse. its as though the lenovo screen was acting like a large touchpad/mouse. I looked in the settings but there doesn't appear to be anything specific to prevent this from occurring on dual screen.
i realise i am completely new to the Linux environments so perhaps i missed something obvious.
Thanks
Mark
Try this article.
I also have a touchscreen laptop, but I was too lazy (and a little busy) to properly configure my multihead setup.
I may give a try though...
It worked for me:
- Get monitor Xorg names (eDP is my touch monitor)
xrandr | grep -w connected
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
HDMI-A-0 connected 1920x1080+1920+0 (normal left inverted right x axis y axis) 160mm x 90mm
- Get xinput touch input actions/events names (with Wacom in name)
xinput --list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Logitech USB Laser Mouse id=9 [slave pointer (2)]
⎜ ↳ SYN3000:00 06CB:7F28 Mouse id=14 [slave pointer (2)]
⎜ ↳ SYN3000:00 06CB:7F28 Touchpad id=15 [slave pointer (2)]
⎜ ↳ Wacom HID 51C7 Pen stylus id=12 [slave pointer (2)]
⎜ ↳ Wacom HID 51C7 Pen eraser id=17 [slave pointer (2)]
⎜ ↳ Wacom HID 51C7 Finger touch id=13 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Power Button id=8 [slave keyboard (3)]
↳ Ideapad extra buttons id=11 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=16 [slave keyboard (3)]
↳ Integrated Camera: Integrated C id=10 [slave keyboard (3)]
- Assign touch functions to touchscreen monitor
xinput --map-to-output 'Wacom HID 51C7 Finger touch' eDP
xinput --map-to-output 'Wacom HID 51C7 Pen eraser' eDP
xinput --map-to-output 'Wacom HID 51C7 Pen stylus' eDP
Fixed!
Before this, my touchscreen was sending actions to both laptop and external monitor (left half to laptop, right half to external).
Now it works only on laptop, like normal.
You may use a script with the last set of commands (xinput --map-to-output
) and run manually when adding external monitor, or use a udev rule, as explained in Archwiki.
