Please provide your
As per the forum template
It helps us to help you
Here is my garuda-inxi result:
Kernel: 6.10.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=ff70cbe1-f024-4a59-a989-73d9109de43b rw rootflags=subvol=@
quiet resume=UUID=a84eb5e8-6eb6-4391-8807-f83069f23200 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: Micro-Star product: Katana GF76 11UC v: REV:1.0
Mobo: Micro-Star model: MS-17L2 v: REV:1.0 serial: <superuser required>
part-nu: 17L2.3 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E17L2IMS.319 date: 07/27/2023
ID-1: BAT1 charge: 49.2 Wh (98.4%) condition: 50.0/52.0 Wh (96.1%)
volts: 12.9 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x52
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 908 high: 2055 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 1288
4: 800 5: 2055 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 bogomips: 73728
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel alternate: xe arch: Gen-12.1 process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 560.35.03 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a2
class-ID: 0302
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
device-ID: 8086:9a60 memory: 7.48 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (TGL GT1) driver: mesa intel v: 24.2.1-arch1.1
device-ID: 8086:9a60 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3050 Laptop GPU driver: nvidia
v: 560.35.03 device-ID: 10de:25a2 surfaces: xcb,xlib,wayland device: 2
v: 24.2.1-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0401
API: ALSA v: k6.10.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:3 chip-ID: 8087:0026
Local Storage: total: 2.29 TiB used: 310.23 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA001 temp: 35.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: Expansion HDD
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 1901 scheme: GPT
ID-1: / raw-size: 459.78 GiB size: 459.78 GiB (100.00%) used: 24 GiB (5.2%)
ID-3: /home raw-size: 459.78 GiB size: 459.78 GiB (100.00%)
used: 24 GiB (5.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 459.78 GiB size: 459.78 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.78 GiB size: 459.78 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.32 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.86 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 57.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.33 GiB used: 4.09 GiB (26.7%)
Processes: 393 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1531 libs: 391 tools: octopi,paru Compilers:
gcc: 14.2.1 alt: 13 Shell: garuda-inxi default: Zsh v: 5.9
System install date: 2024-09-03
Last full system update: 2024-09-04 ↻
Use Fn+F4 on the keyboard to disable/enable the touchpad.
