Hello guys,
I have a SynPS/2 Synaptics TouchPad
and I have installed xf86-input-synaptics
drivers which allows me to change a lot. But the scrolling sensitivity/speed is too high and I can't find an option to reduce that.
Is there a way I can reduce it?
Thank you
filo
24 September 2021 05:24
2
Please provide your inxi -Faz as text and formatted, as per new topic template.
System: Kernel: 5.14.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=fe1af568-2885-4a8e-bc9a-c6b70a7e48bf
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Mobo: WALTON model: WTEX4105SL serial: <filter> UEFI: INSYDE v: 1.07.03TWM date: 08/22/2019
Battery: ID-1: BAT0 charge: 34.4 Wh (98.6%) condition: 34.9/35.3 Wh (98.9%) volts: 12.6 min: 11.4
model: Notebook BAT type: Li-ion serial: <filter> status: Discharging
CPU: Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: C (12) microcode: EA cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33599
Speed: 1593 MHz min/max: 400/1600 MHz Core speeds (MHz): 1: 1593 2: 1487 3: 1578 4: 1549
5: 1585 6: 1598 7: 1575 8: 1595
Graphics: Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 04f2:b649 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: intel
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.2 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.7-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel port: 5000
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK
driver: r8169 v: kernel port: 3000 bus-ID: 06:00.1 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0f1 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
Drives: Local Storage: total: 476.94 GiB used: 12.1 GiB (2.5%)
ID-1: /dev/sda maj-min: 8:0 model: IM3D B16A SSD size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 7A0 scheme: GPT
Partition: ID-1: / raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 12.07 GiB (30.9%) fs: btrfs
dev: /dev/sda7 maj-min: 8:7
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%) used: 28.2 MiB (29.7%) fs: vfat
dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 12.07 GiB (30.9%) fs: btrfs
ID-4: /var/log raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 12.07 GiB (30.9%) fs: btrfs
ID-5: /var/tmp raw-size: 39.06 GiB size: 39.06 GiB (100.00%) used: 12.07 GiB (30.9%) fs: btrfs
ID-1: swap-1 type: zram size: 7.46 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A
Info: Processes: 261 Uptime: 3m wakeups: 2 Memory: 7.46 GiB used: 2.31 GiB (30.9%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1271 apt: 1 pacman: 1270
lib: 336 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
filo
24 September 2021 06:19
4
First off, I'd check touchpad in system settings and relevant options.
But I guess you already did it.
You then could check here.
https://wiki.archlinux.org/title/Touchpad_Synaptics#Frequently_used_options
E.g., but not limited to:
If your touchpad is too sensitive, use higher values for FingerLow
and FingerHigh
and vice versa. Remember that FingerLow
should be smaller than FingerHigh
Hello,
Thanks for that.
I realized that the config file is not working. I disabled touchpad and it is still working. What am I doing wrong? Do I need to do a restart after editing a config file?
filo
24 September 2021 07:21
6
I think a reboot is always the best solution, although after xorg changes you have to restart the X server (so maybe a logoff/logon would be ok, even just a startx
Maybe it is not working due to this initial warning in the wiki?
This article details the installation and configuration process of the Synaptics input driver for Synaptics (and ALPS) touchpads found on most notebooks.
Warning: xf86-input-synaptics is no longer actively updated. If possible, use libinput . For some reasons why you might still prefer xf86-input-synaptics , see, e.g. [1] and [2] .
Note: If you want to configure touchpad via GNOME Settings, you need to use the libinput driver.[3]
Yes thank you.
Changing VertScrollDelta
did the trick for me. I set it to around -260.
PS :
This article also helped me - Finally real smooth scrolling on Linux with the touchpad and Chrome 54
filo
25 September 2021 10:06
8
system
Closed
27 September 2021 10:07
9
