Touchpad not working after restart
after restart touchpad not working on lenovo ideaipad 3 15iil05.
When I installed OS, the touchpad also did not work, but I was helped by editing the GRUB file (grub_cmdline_linux_default)
Restarted or reinstalled, as I see in another topic?
Any which way, I think you should check the grub file in your initial topic and if necessary redo the steps.
Oooops, sorry I did not correctly explained. not after reboot, and after turning on the laptop from the sleep mode
file GRUB without changes
