Touchpad issue
I am having issues with my trackpad.
After a period of inactivity tracking becomes edgy or does not work at all.
I have to reboot to get it working properly again.
Any suggestions?
lsmod | grep -i psmouse
psmouse               245760  0
libps2                 20480  2 atkbd,psmouse
serio                  28672  6 serio_raw,atkbd,psmouse,i8042
anarcho@LuNoHo:~$sudo dmesg | grep -i touchpad
[    2.574317] input: DLL07BF:01 06CB:7A13 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL07BF:01/0018:06CB:7A13.0001/input/input7
[    2.648309] input: DLL07BF:01 06CB:7A13 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-DLL07BF:01/0018:06CB:7A13.0001/input/input10
xinput --list-props "DLL07BF:01 06CB:7A13 Touchpad"
Device 'DLL07BF:01 06CB:7A13 Touchpad':
        Device Enabled (212):   1
        Coordinate Transformation Matrix (214): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
        libinput Tapping Enabled (342): 0
        libinput Tapping Enabled Default (343): 0
        libinput Tapping Drag Enabled (344):    1
        libinput Tapping Drag Enabled Default (345):    1
        libinput Tapping Drag Lock Enabled (346):       0
        libinput Tapping Drag Lock Enabled Default (347):       0
        libinput Tapping Button Mapping Enabled (348):  1, 0
        libinput Tapping Button Mapping Default (349):  1, 0
        libinput Natural Scrolling Enabled (350):       0
        libinput Natural Scrolling Enabled Default (351):       0
        libinput Disable While Typing Enabled (352):    1
        libinput Disable While Typing Enabled Default (353):    1
        libinput Scroll Methods Available (354):        1, 1, 0
        libinput Scroll Method Enabled (355):   1, 0, 0
        libinput Scroll Method Enabled Default (356):   1, 0, 0
        libinput Click Methods Available (357): 1, 1
        libinput Click Method Enabled (358):    0, 1
        libinput Click Method Enabled Default (359):    1, 0
        libinput Clickfinger Button Mapping Enabled (360):      1, 0
        libinput Clickfinger Button Mapping Default (361):      1, 0
        libinput Middle Emulation Enabled (362):        0
        libinput Middle Emulation Enabled Default (363):        0
        libinput Accel Speed (364):     0.000000
        libinput Accel Speed Default (365):     0.000000
        libinput Accel Profiles Available (366):        1, 1, 1
        libinput Accel Profile Enabled (367):   1, 0, 0
        libinput Accel Profile Enabled Default (368):   1, 0, 0
        libinput Accel Custom Fallback Points (369):    <no items>
        libinput Accel Custom Fallback Step (370):      0.000000
        libinput Accel Custom Motion Points (371):      <no items>
        libinput Accel Custom Motion Step (372):        0.000000
        libinput Accel Custom Scroll Points (373):      <no items>
        libinput Accel Custom Scroll Step (374):        0.000000
        libinput Left Handed Enabled (375):     0
        libinput Left Handed Enabled Default (376):     0
        libinput Send Events Modes Available (327):     1, 1
        libinput Send Events Mode Enabled (328):        0, 0
        libinput Send Events Mode Enabled Default (329):        0, 0
        Device Node (330):      "/dev/input/event6"
        Device Product ID (331):        1739, 31251
        libinput Drag Lock Buttons (377):       <no items>
        libinput Horizontal Scroll Enabled (378):       1
        libinput Scrolling Pixel Distance (379):        15
        libinput Scrolling Pixel Distance Default (380):        15
        libinput High Resolution Wheel Scroll Enabled (381):    1
  Kernel: 6.12.13-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=cfe58ff1-10f6-4a0f-bf00-e7c82f3b3a89 rw rootflags=subvol=@
    quiet resume=UUID=804a5b91-748b-4e0e-9b50-cd4994cf4a32 loglevel=3
    snd_hda_intel.dmic_detect=0 ibt=off
  Type: Laptop System: Dell product: Precision 5520 v: N/A
  Mobo: Dell model: 0R6JFH v: A00 serial: <superuser required> part-nu: 07BF
    uuid: <superuser required> UEFI: Dell v: 1.40.0 date: 09/03/2024
  ID-1: BAT0 charge: 59.3 Wh (100.0%) condition: 59.3/97.1 Wh (61.1%)
    volts: 12.5 min: 11.8 model: LGC-LGC8.33 DELL 5XJ28 type: Li-ion
    serial: <filter> status: full
  Info: model: Intel Core i7-7820HQ bits: 64 type: MT MCP arch: Kaby Lake
  Speed (MHz): avg: 1160 min/max: 800/3900 scaling: driver: intel_pstate
    governor: performance cores: 1: 1160 2: 1160 3: 1160 4: 1160 5: 1160 6: 1160
    7: 1160 8: 1160 bogomips: 46419
  Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:591b
  Device-2: NVIDIA GM107GLM [Quadro M1200 Mobile] vendor: Dell
    arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
    chip-ID: 10de:13b6 class-ID: 0302
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:3
    chip-ID: 0c45:6713 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
  Monitor-1: eDP-1 model: Sharp 0x1453 built: 2015 res: mode: 1920x1080
    hz: 60 scale: 100% (1) dpi: 141 gamma: 1.2 size: 346x194mm (13.62x7.64")
    diag: 397mm (15.6") ratio: 16:9 modes: 1920x1080
    drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
    drv: iris inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    device-ID: 8086:591b memory: 15.17 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: integrated-gpu name: Intel
    HD Graphics 630 (KBL GT2) driver: N/A device-ID: 8086:591b
    surfaces: xcb,xlib device: 1 type: discrete-gpu name: Quadro M1200
    driver: N/A device-ID: 10de:13b6 surfaces: xcb,xlib device: 2 type: cpu
    name: llvmpipe (LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
    surfaces: xcb,xlib
  Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  API: ALSA v: k6.12.13-1-lts status: kernel-api
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b2 class-ID: 0280
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
    wpa_supplicant
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 8087:07dc
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 1.86 TiB used: 1.36 TiB (73.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
    lanes: 4 tech: SSD serial: <filter> fw-rev: 42AZS6AC temp: 35.9 C
  ID-1: / raw-size: 1.83 TiB size: 1.83 TiB (100.00%) used: 1.36 TiB (74.5%)
    used: 20.1 MiB (6.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
    used: 1.36 TiB (74.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-4: /var/log raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
  ID-5: /var/tmp raw-size: 1.83 TiB size: 1.83 TiB (100.00%)
  ID-1: swap-1 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
  ID-2: swap-2 type: zram size: 31.07 GiB used: 15 MiB (0.0%) priority: 100
  System Temperatures: cpu: 58.0 C pch: 52.5 C mobo: 51.0 C
  Fan Speeds (rpm): cpu: 2501 fan-2: 2517
  Memory: total: 32 GiB note: est. available: 31.07 GiB used: 8.38 GiB (27.0%)
  Processes: 363 Power: uptime: 2h 14m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,upowerd
  Packages: 1754 pm: pacman pkgs: 1753 libs: 468 tools: octopi,paru
    pm: flatpak pkgs: 1 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
    default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
Garuda (2.6.26-1.1):
  System install date:     2024-05-31
  Last full system update: 2025-02-11
After a certain period of inactivity of the touchpad or the entire laptop?
Disable while typing is set to enabled. Check if you still have the issue after disabling the option in the KDE settings → Mouse & Touchpad → Touchpad. Should have nothing to do with your issue, but you never know.
The most likely trigger for the issue could also be the power management. Have you set an automatic change of the energy profile after a specified time in the KDE settings under Power Management → Other Settings?
If so, set it to “Leave unchanged” (or set a user-defined timer for “When inactive”) and then check whether the issue still occurs.
Thank you for the reply!
That sound like it might be relevant.
I had power issues recently
here
I thought this was solved as I no longer got error messages when updating but the crashing still occurs.
I do not see same settings though! There is no “Leave unchanged”.
Please answer all questions.
Do you also have the issues if you deactivate ALL energy-saving options?
