Touchpad doesn't work on lxqt
Hello,
I can't make my touchpad work. This is a long standing issue on my laptop with arch based distors, but up until now, I could solve the problem by creating a 30-touchpad.conf file and copying it in the /etc/X11/xorg.conf.d folder. But this time the trick doesn't work.
Can anyone help me identifying the source of the problem?
Thank you.
hwinfo --short
cpu:
                       Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz, 3100 MHz
keyboard:
  /dev/input/event5    AT Translated Set 2 keyboard
mouse:
  /dev/input/mice      Elan Microelectronics Touchscreen
                       Logitech Unifying Receiver
  /dev/input/mice      DELL0741:00 06CB:7E7E Mouse
  /dev/input/mice      DELL0741:00 06CB:7E7E Touchpad
monitor:
                       6NKDX NV13FHM LCD Monitor
graphics card:
                       Intel HD Graphics 620
sound:
                       Intel Sunrise Point-LP HD Audio
storage:
                       Intel Sunrise Point-LP SATA Controller [AHCI mode]
network:
  wls8                 Intel Wireless 3165
network interface:
  lo                   Loopback network interface
  wls8                 Ethernet network interface
disk:
  /dev/zram1           Disk
  /dev/sda             SanDisk Z400s M.
  /dev/zram0           Disk
partition:
  /dev/sda1            Partition
  /dev/sda2            Partition
  /dev/sda3            Partition
  /dev/sda4            Partition
  /dev/sda5            Partition
  /dev/sda6            Partition
usb controller:
                       Intel Sunrise Point-LP USB 3.0 xHCI Controller
bios:
                       BIOS
bridge:
                       Intel Sunrise Point-LP PCI Express Root Port #5
                       Intel Sunrise Point-LP LPC Controller
                       Intel Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
hub:
                       Linux Foundation 2.0 root hub
                       Linux Foundation 3.0 root hub
memory:
                       Main Memory
bluetooth:
                       Intel Bluetooth Device
unknown:
                       FPU
                       DMA controller
                       PIC
                       Keyboard controller
                       Intel Sunrise Point-LP PMC
                       Intel Sunrise Point-LP Serial IO I2C Controller #1
                       Intel Sunrise Point-LP Integrated Sensor Hub
                       Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem
                       Intel Sunrise Point-LP CSME HECI #1
                       Intel Sunrise Point-LP Serial IO I2C Controller #0
                       Intel Sunrise Point-LP Thermal subsystem
                       Intel Sunrise Point-LP SMBus
                       Realtek Integrated_Webcam_HD
Laptops aren't my thing. I only ever install Linux on laptops for friends and family now and then.
So, I'm far from an expert on laptop workings. I'm sure someone more knowledgeable than myself will wander by to help you. In the mean time check if you have xf86-input-libinput installed.
xf86-input-libinput is installed.
I forgot to mention that only the right side of the touchpad doesn't work. I can scroll but I can't click buttons.
Device:           DELL0741:00 06CB:7E7E Touchpad
Kernel: /dev/input/event10
Group: 9
Seat: seat0, default
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: *button-areas clickfinger
Disable-w-typing: enabled
Accel profiles: flat *adaptive
Rotation: n/a
