sh-5.1$ sudo pacman -S linux-tkg-bmq-$(gcc -c -Q -march=native --help=target | grep march |head -1|awk '{print$2}'){,-headers}
error: target not found: linux-tkg-bmq-skylake
error: target not found: linux-tkg-bmq-skylake-headers
I also cannot find the linux-tkg-pds-skylake kenerls either.
inxi -Fxxxza
System: Kernel: 5.11.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=4cc7ed72-608e-41ae-b29b-3adb668888b7
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0 serial: <filter> Chassis: type: 10
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16U5IMS.101 date: 07/02/2019
Battery: ID-1: BAT1 charge: 44.0 Wh (100.0%) condition: 44.0/51.6 Wh (85.3%) volts: 12.0 min: 10.9
model: MSI BIF0_9 type: Li-ion serial: N/A status: Full
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: A (10) microcode: DE cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4401 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 4401 2: 4401 3: 4390 4: 4400
5: 4401 6: 4401 7: 4400 8: 4402 9: 4402 10: 4373 11: 4321 12: 4400
Graphics: Device-1: Intel UHD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI driver: nvidia
v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5 chip-ID: 04f2:b695
class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 120 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.0.1 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.11.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.25 running: no
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Report: ID: hci0 state: up address: <filter>
Drives: Local Storage: total: 1.38 TiB used: 11.15 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-512G-1032
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2
rotation: SSD serial: <filter> rev: 20140000 temp: 46.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPVX-60JC3T0 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: 1A01 scheme: GPT
Partition: ID-1: / raw-size: 73.24 GiB size: 73.24 GiB (100.00%) used: 11.12 GiB (15.2%) fs: btrfs
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%) used: 26.3 MiB (8.9%) fs: vfat
ID-3: /home raw-size: 73.24 GiB size: 73.24 GiB (100.00%) used: 11.12 GiB (15.2%) fs: btrfs
ID-4: /var/log raw-size: 73.24 GiB size: 73.24 GiB (100.00%) used: 11.12 GiB (15.2%) fs: btrfs
ID-5: /var/tmp raw-size: 73.24 GiB size: 73.24 GiB (100.00%) used: 11.12 GiB (15.2%) fs: btrfs
ID-1: swap-1 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A
Info: Processes: 304 Uptime: 7m wakeups: 1 Memory: 15.47 GiB used: 2.94 GiB (19.0%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1360 lib: 342
Shell: fish v: 3.2.1 running-in: konsole inxi: 3.3.03
