inxi -Faz
System: Kernel: 5.14.9-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c7830645-81ec-4575-b78e-6054ff59983c rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=UUID=c1d80959-5bb6-44ff-9bff-7d85ab6c3145 loglevel=3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Acer product: Aspire A515-44 v: V1.12 serial: <filter>
Mobo: RO model: Calla_RN v: V1.12 serial: <filter> UEFI: INSYDE v: 1.12 date: 03/15/2021
Battery: ID-1: BAT1 charge: 12.4 Wh (22.8%) condition: 54.4/53.0 Wh (102.7%) volts: 14.3 min: 15.4 model: PANASONIC AP19B5L
type: Li-ion serial: <filter> status: Discharging
CPU: Info: 8-Core model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600103 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 31943
Speed: 1344 MHz min/max: 1400/2000 MHz boost: enabled Core speeds (MHz): 1: 1344 2: 1397 3: 2468 4: 1973 5: 2206
6: 2422 7: 1607 8: 1248
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir vendor: Acer Incorporated ALI driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-4:2 chip-ID: 0408:a061 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.14.9-zen2-1-zen LLVM 12.0.1) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Acer Incorporated ALI
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.14.9-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci v: kernel
port: 2000 bus-ID: 04:00.0 chip-ID: 168c:003e class-ID: 0280
Bluetooth: Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 04ca:3016 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Drives: Local Storage: total: 942.7 GiB used: 204.51 GiB (21.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 SDAPNUW-512G-1014 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: 20110000
temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-SSHD-8GB size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LVD3 scheme: GPT
Partition: ID-1: / raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 204.51 GiB (43.7%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 547 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 204.51 GiB (43.7%) fs: btrfs dev: /dev/nvme0n1p2
maj-min: 259:2
ID-4: /var/log raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 204.51 GiB (43.7%) fs: btrfs
ID-5: /var/tmp raw-size: 467.88 GiB size: 467.88 GiB (100.00%) used: 204.51 GiB (43.7%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: swap-2 type: zram size: 18.92 GiB used: 1.88 GiB (9.9%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 60.8 C mobo: N/A gpu: amdgpu temp: 51.0 C
Info: Processes: 301 Uptime: 18m wakeups: 1 Memory: 18.92 GiB used: 4.75 GiB (25.1%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1749 pacman: 1741 lib: 475 snap: 8 Shell: fish v: 3.3.1
running-in: konsole inxi: 3.3.06
The Problem is my Titlebar Buttons are disordered. But i cant order them back because the settings are not quite working. When i add the button to the title bar in the settings i cant move it because it just disappears in the settings but it adds it to the titlebar.
Is there a reset for the Titlebar Buttons somewhere?
