Hello just installed wayfire
So not much to say ... Nothing shows when I click on that programs icons.
Some others programs also are not working here .
Had the same isues in other pc before but I left it.
Can I fix it? Cannot download another linux within two weeks so in stuck with windows
Iso is from Garuda website.
Sorry for phone dictionary just fixed
`[quote="Vandal7, post:1, topic:10396, full:true"]
inxi -Fza
>inxi -Fza'
SGS
12 July 2021 04:37
#2
Vandal7:
wireframe
How did you install this and where did this app come from and what does it do.
Vandal7:
oc.
oc = overclocked?
Again, like in template, read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your…
please
and post
inxi -Fza
as text!
Even if you personally think it is unnecessary.
and
Naman
12 July 2021 05:53
#3
Hi @Vandal7 .
It looks like there is some misunderstanding due to language barriers.
You can post in your native language in #languages category.
Thanks for understanding.
I'm sorry writed it fast and do not watched what my dictionary is doing with text - its correct now.
Also is from Garuda webside.
SGS
12 July 2021 14:36
#5
Again
What is wireframe?
Please, post terminal in- and output from
inxi -Fza
as text!
There are 13 DE's on the web page and many other things.
You have to describe it more precisely.
i do not know how you making this
inxi -Fza
in color, sory i do not understand this turtorial
i'm sory once again for writing stupid things
i have Garuda Wayfire from
Garuda Linux comes with a variety of desktop environments like KDE, Xfce, GNOME, LXQt-kwin, Wayfire, Qtile, BSPWM, i3wm and Sway to choose from.
i got lucky and have fast internet so i try LXQT version, and hope it will work. i'm sory for disturbing you. Can delete the post now
SGS
12 July 2021 17:33
#7
Open Terminal/Konsole type
inxi -Faz
you got similar like this
╭─[email protected] in ~ took 5ms
╰─λ inxi -Faz
System: Kernel: 5.12.15-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=00a0c0cb-8fbe-4bbf-a7ef-72f4d595947f rw
[email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop Mobo: ASUSTeK model: P8Z77-V DELUXE v: Rev 1.xx serial: <filter> UEFI: American Megatrends v: 2104
date: 08/13/2013
CPU: Info: Quad Core model: Intel Core i7-3770K bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
stepping: 9 microcode: 21 cache: L2: 8 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57691
Speed: 4085 MHz min/max: 1600/4100 MHz Core speeds (MHz): 1: 4085 2: 4093 3: 3666 4: 3900 5: 4230 6: 3924 7: 2159
8: 2733
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: ZOTAC driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm
bus-ID: 01:00.0 chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org 1.20.12 driver: loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.7x13.4") s-diag: 692mm (27.2")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 164 size: 596x335mm (23.5x13.2") diag: 684mm (26.9")
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 465.31 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:1e20 class-ID: 0403
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.12.15-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.31 running: yes
Network: Device-1: Intel 82579V Gigabit Network vendor: ASUSTeK P8P67 Deluxe driver: e1000e v: kernel port: f040
bus-ID: 00:19.0 chip-ID: 8086:1503 class-ID: 0200
Device-2: Broadcom BCM43228 802.11a/b/g/n vendor: ASUSTeK driver: wl v: kernel modules: bcma port: c000
bus-ID: 0c:00.0 chip-ID: 14e4:4359 class-ID: 0280
IF: wlp12s0 state: down mac: <filter>
Device-3: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8 series driver: r8169 v: kernel
port: b000 bus-ID: 0d:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp13s0 state: down mac: <filter>
Bluetooth: Device-1: ASUSTek BCM20702A0 type: USB driver: btusb v: 0.8 bus-ID: 1-1.1:3 chip-ID: 0b05:17b5 class-ID: fe01
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Drives: Local Storage: total: 6.7 TiB used: 2.53 TiB (37.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Corsair model: Corsair Force GT size: 111.79 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 3 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EACS-22D6B1 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter> rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: HDWQ140 size: 3.64 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter> rev: FJ1M scheme: GPT
ID-5: /dev/sde maj-min: 8:64 type: USB vendor: Toshiba model: External USB 3.0 size: 1.82 TiB block-size:
physical: 512 B logical: 512 B serial: <filter> rev: 5438 scheme: GPT
Partition: ID-1: / raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 53.23 GiB (22.9%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 2.3 MiB (0.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 53.23 GiB (22.9%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 53.23 GiB (22.9%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 232.63 GiB size: 232.63 GiB (100.00%) used: 53.23 GiB (22.9%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 57 C
Fan Speeds (RPM): cpu: 4383 fan-1: 1380 fan-3: 875 fan-4: 898 fan-5: 860 gpu: nvidia fan: 0%
Power: 12v: N/A 5v: N/A 3.3v: 3.30 vbat: 3.34
Info: Processes: 318 Uptime: 1h 00m wakeups: 0 Memory: 15.57 GiB used: 4.84 GiB (31.1%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1490 lib: 349 Shell: fish v: 3.3.1
running-in: xfce4-terminal inxi: 3.3.04
and wireframe are different things.
You don't have to apologise but it would be nice if you checked your details before you sent them. We are not psychics.
Constantly downloading other things will not lead you to your goal, to use a rolling distribution you need some basic knowledge about Arch Linux based operating systems.
This also includes the terminal.
