Taskbar Not Hiding Properly – Requires Kill & Restart Frequently
I’ve been experiencing a recurring issue where the taskbar does not auto-hide properly. I haven’t made any external modifications to it. Normally, I can temporarily fix it by manually restarting the process, but this gets frustrating since I have to repeat it often.
Today, the issue was worse than usual, the taskbar wouldn’t hide at all, even after restarting it multiple times. A system reboot finally resolved the problem, but I’d like to find a permanent fix.
Steps to Reproduce:
  1. Enable auto-hide for the KDE taskbar.
  2. Use the system normally for some time.
  3. Eventually, the taskbar stops hiding.
  4. Running killall plasmashell && kstart5 plasmashell usually resolves it, but the issue comes back.
  5. Today, even that didn’t work until I rebooted.
What I’ve Tried So Far:
  • Restarting plasmashell (killall plasmashell && kstart5 plasmashell).
  • Checking for running background processes that might interfere.
  • Searching online and the forums, but couldn’t find a working solution.
  • Rebooting the system (sometimes helps, but not always).
System Information:
clocksource: tsc
Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
serial: <filter> uuid: c84a3533-a446-7115-a3c8-047c164c0828 UEFI: American
Megatrends LLC. v: 2.E0 date: 03/06/2023
Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB
L3: 16 MiB
Speed (MHz): avg: 400 min/max: 400/3901 boost: enabled volts: 1.4 V
ext-clock: 100 MHz cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 93424
Device-1: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] driver: amdgpu v: kernel arch: GCN-5 pcie:
speed: 8 GT/s lanes: 16 ports: active: DP-1 empty: DP-2,HDMI-A-1
bus-ID: 30:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 42.0 C
Display: unspecified server: X.Org v: 24.1.6 with: Xwayland v: 24.1.6
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: DP-1 model: Acer VG270 S serial: <filter> res: mode: 1920x1080
hz: 165 scale: 100% (1) dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27") modes: max: 1920x1080 min: 720x400
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
renoir ACO DRM 3.61 6.13.8-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.4.309 layers: 5 surfaces: xcb,xlib device: 0
type: integrated-gpu driver: N/A device-ID: 1002:1638 device: 1 type: cpu
driver: N/A device-ID: 10005:0000
Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie:
speed: 8 GT/s lanes: 16 bus-ID: 30:00.1 chip-ID: 1002:1637 class-ID: 0403
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s
lanes: 16 bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Actions K2 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 5-2:2 chip-ID: 10d6:4801
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 1.4.1 status: n/a (root, process) with:
Device-1: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 14c3:0608 class-ID: 0280
IF: wlp41s0 state: up mac: <filter>
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: speed: 2.5 GT/s
IF: enp42s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 bus-ID: 1-9:5 chip-ID: 0e8d:0608 class-ID: e001
lmp-v: 11 class-ID: 6c0104
Local Storage: total: 1.38 TiB used: 10.67 GiB (0.8%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P3SSD8 size: 465.76 GiB
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR30A
temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Crucial model: CT1000P3SSD8 size: 931.51 GiB
temp: 37.9 C scheme: GPT
ID-3: /dev/sda vendor: SanDisk model: Cruzer Blade size: 14.34 GiB
type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-1: / size: 67.96 GiB used: 10.67 GiB (15.7%) fs: btrfs
dev: /dev/nvme1n1p7
ID-2: /boot/efi size: 548.9 MiB used: 608 KiB (0.1%) fs: vfat
dev: /dev/nvme1n1p4
ID-3: /home size: 67.96 GiB used: 10.67 GiB (15.7%) fs: btrfs
dev: /dev/nvme1n1p7
ID-4: /var/log size: 67.96 GiB used: 10.67 GiB (15.7%) fs: btrfs
dev: /dev/nvme1n1p7
ID-5: /var/tmp size: 67.96 GiB used: 10.67 GiB (15.7%) fs: btrfs
dev: /dev/nvme1n1p7
ID-1: swap-1 type: zram size: 27.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.1 C mobo: 38.0 C gpu: amdgpu temp: 42.0 C
Memory: total: 28 GiB available: 27.29 GiB used: 4.85 GiB (17.8%)
Processes: 407 Power: uptime: 2m states: freeze,mem,disk suspend: deep
wakeups: 0 hibernate: platform Init: systemd v: 257 default: graphical
Packages: pm: pacman pkgs: 1304 Compilers: gcc: 14.2.1 Shell: Sudo (sudo)
v: 1.9.16p2 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
Additional Notes:
  • The issue is random but happens frequently.
  • I have not made any external modifications to the taskbar.
  • A reboot today resolved it, but that’s not a reliable fix.
Please post full garuda-inxi.
On KDE after updates, restart your system.
We can’t fix it, open issue on KDE :slight_smile:
Or just try X11, not Wayland from login screen.
Typically it’s a process running that for some reason you’re not seeing on the panel and it has focus. If the case you need to ferret out which process is the issue.
I fetched the output after a reboot, as requested. As for KDE, I found an open bug report on this issue (#478797), but it’s been sitting there for almost two years without a fix. If reporting to KDE actually worked, this should’ve been resolved by now. I also found a similar case in the Garuda forums (this post), so it’s definitely not just me facing this.
I originally used the <details> tag just to keep the post cleaner, but I see now that full inline output is preferred. My bad on that. I’ll try X11 and report back if anything changes.
Also, not to be rude, but I really think this issue is worth looking into. Just because one user (me) reports it doesn’t mean it should be left off the fix list, especially when it’s been affecting people for so long.
Just to clarify, I’m not putting this on the Garuda devs, I get that priorities are different. I was just hoping for some workarounds, like the X11 suggestion you mentioned, which I’ll try now : -)
Install and test at least three alternate kernels.
When did this problem start?
Does it behave the same in the live environment?
That makes sense. But in my case, it mostly happens when the screen is left unattended, like if I’m just watching something without interacting with the system, or if it goes into an auto sleep state. That’s when the taskbar gets stuck and refuses to auto-hide.
Is there a way to check what process might be causing this when it happens?
Edit:
  • It also occurs when I place a PiP (picture-in-picture) video too close to the taskbar. Even after moving it away, the taskbar still won’t hide.
Got it, I’ll test with a few alternate kernels and see if that changes anything.
As for when it started, I actually got the OS just three days ago (maybe ±2), but it’s relatively new, and this issue was there right from the first installation, without modifying anything, straight out of the box.
I haven’t checked in a live environment yet, but I’ll try that as well and report back.
Commands you could test to restart plashmashell & kwin:
For an X11 session:
bash -c 'plasmashell --replace > /dev/null 2>&1 & disown; sleep 5; systemctl --user restart plasma-kwin_x11.service > /dev/null 2>&1 & disown; sleep 2; exit'
For a Wayland session:
bash -c 'systemctl --user restart plasma-plasmashell > /dev/null 2>&1 & disown; sleep 5; systemctl --user restart plasma-kwin_wayland  > /dev/null 2>&1 & disown; sleep 2; exit'
In the above^^^ command restarting kwin_wayland will likely result in losing your currently open programs stored session information.
Using kwin_wayland --replace may allow you to retain your session information.
Further commands you could try:
systemctl --user restart plasmashell
plasmashell --replace & disown
plasmashell restart
kquitapp6 plasmashell; kstart plasmashell
kquitapp6 plasmashell && kstart plasmashell > /dev/null 2>&1 & disown; sleep 2; exit
Edited in other command variations.
For now try what tbg posted and see what you get. If any of that doesn’t do the trick try replacing the panel. I just ran into an issue with my install of the new ISO I’m not seeing anyone else have and the only solution for me was to replace the panel.
EDIT:
You could also play with the settings if you haven’t yet to see if that forces it to behave. Switch to Doge or always shown, logout, run a couple of things, switch back, logout again, and test again.
