Tapping superkey does not launch widget
A few days earlier Garuda asked me to migrate from Latte-Dock to KDE's panels and since then, tapping SuperKey alone does not launch the Application Launcher/Application Menu.
I have tried to configured the shortcut (Alt+F1) in both the Application Launcher settings and in global shortcuts and it still won't work.
Some guides suggest to assign Meta+F1 or Meta+Spacebar, but I already have them assigned.
I tried to delete anything related to Application Launcher in ~/.config/kglobalshortcutsrc and then re-assign Alt+f1 through GUI and still nothing.
I tried deleting and re-adding the widget. Also tried to add Application Menu and assign Alt+F1. Still nothing.
Couldn't find any recent issues on KDE forums. All the posts that I looked into suggested the Alt+F1 approach.
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=1d17e6de-9557-4600-a71d-2fc817db7784 rw [email protected]
quiet
cryptdevice=UUID=ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d:luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
root=/dev/mapper/luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d quiet splash
resume=/dev/mapper/luks-253338ee-7144-43f5-bc83-a762863e12f3 loglevel=3
mitigations=off ibt=off
Desktop: KDE Plasma v: 5.27.0 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713QM.321 date: 09/07/2022
ID-1: BAT0 charge: 51.6 Wh (60.0%) condition: 86.0/90.0 Wh (95.5%)
volts: 15.6 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1199 high: 1200 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1200 2: 1200
3: 1198 4: 1200 5: 1200 6: 1198 7: 1200 8: 1200 9: 1200 10: 1200 11: 1200
12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 bogomips: 102206
link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1 off: eDP-1
empty: none bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 33.0 C
compositor: kwin_x11 driver: X: loaded: modesetting dri: radeonsi
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Acer B246WL serial: <filter>
built: 2020 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
Monitor-2: eDP-1 note: disabled pos: primary model: AU Optronics 0x8294
built: 2020 res: 1920x1200 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.49 6.1.12-zen1-1-zen) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-2.4:6 chip-ID: 0c76:1620 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
Device-4: JMTek LLC. USB PnP Audio Device type: USB
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:5
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 4.98 TiB used: 2.25 TiB (45.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX013N
lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.13 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.14 GiB block-size: physical: 512 B
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD40NDZW-11A8JS1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 4008 scheme: GPT
ID-1: / raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
used: 133.95 GiB (31.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-ccf6a087-7f6c-4357-9cb5-8bf35bb72a1d
used: 752 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-4: /var/log raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 430.27 GiB size: 430.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.05 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.56 GiB used: 0 KiB (0.0%)
mapped: luks-253338ee-7144-43f5-bc83-a762863e12f3
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 33.0 C
Processes: 413 Uptime: 1h 6m wakeups: 7 Memory: 15.05 GiB
used: 4.76 GiB (31.6%) Init: systemd v: 253 default: graphical
pkgs: 2203 libs: 568 tools: octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2022-10-03
Last full system update: 2023-02-21
https://wiki.garudalinux.org/en/dr460nized-migration
Application Launcher section
