I have two systems running garuda that both suffer from the same issue of audio intermittently failing to start, causing me to have to close and reopen applications or refresh web pages to resolve. This issue has been ongoing for several months, on my second computer since about the time I installed Garuda.
I notice this mostly browsing, because its something I do on both computers more than anything else, but I've also noticed in VLC. I have also tested in multiple browsers such as Vivaldi, so I do not believe it to be the browser or application.
Example behavior would be clicking a link to open a video on youtube in a new tab. Video loads, starts and plays but without audio. Refresh video, usually audio returns. Occasionally it does not and requires multiple refreshes.
Both computers running Garuda do this. I believed it to be EasyEffects at fault because I ran global volume normalizers and equalizers. I disabled EasyEffects on both computers and issue persists when no active easyeffects process, including after restart with no flag to launch easyeffects at startup. When this issue occurs, I can mouse wheel my volume and hear sound, so its very brief and seems like just a failure for something to initialize after a period of no audio activity.
What might I want to change or reinstall to resolve?
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=eaa1f1c6-9940-4c37-9baf-9750aa94737c rw rootflags=subvol=@
splash
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: MAXIMUS VIII HERO v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 3802
date: 03/15/2018
Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4425 high: 4801 min/max: 800/4800 scaling:
driver: intel_pstate governor: performance cores: 1: 4200 2: 4801 3: 4200
4: 4200 5: 4800 6: 4200 7: 4801 8: 4200 bogomips: 67200
vulnerable
PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: XFX Speedster MERC 319 driver: amdgpu v: kernel arch: RDNA-2
speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:73bf class-ID: 0300
Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
s-diag: 1407mm (55.38")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 2560x1440
hz: 165 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 pos: left model: AOC AG271QG4
serial: <filter> built: 2016 res: 2560x1440 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 14.0.6 DRM 3.48 6.0.8-zen1-1-zen) direct render: Yes
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-10:6 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
address: <filter>
Local Storage: total: 10.68 TiB used: 5.22 TiB (48.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 type: SSD serial: <filter> rev: RKT401.3 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Sabrent model: Rocket 4.0 1TB
lanes: 4 type: SSD serial: <filter> rev: RKT401.3 temp: 28.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWE150 size: 4.55 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 7200 serial: <filter> rev: FP2A scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST240HM000-1G5152
size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: C675 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40EZRX-00SPEB0 size: 3.64 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: MBR
used: 516.46 GiB (55.5%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:6
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
ID-1: swap-1 type: zram size: 31.29 GiB used: 1.27 GiB (4.1%)
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 32.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1516
Processes: 361 Uptime: 5d 8h 1m wakeups: 0 Memory: 31.29 GiB
used: 7.76 GiB (24.8%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1977
pm: pacman pkgs: 1964 libs: 528 tools: octopi,pamac,paru pm: flatpak
pkgs: 13 Shell: fish v: 3.5.1 running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-06-13
Last full system update: 2022-11-14 ↻
Snapshots: Timeshift
Failed units: mnt-Josie-Videos.mount shadow.service
