Greetings. So as the title tells, the system hangs after some time using just woken up Laptop.
My garuda-inxi
root=UUID=17ac736c-821f-4582-b5e0-92bdc9ea07d0 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 82RG v: Legion 5 Pro 16ARH7H
serial: <filter> Chassis: type: 10 v: Legion 5 Pro 16ARH7H serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN serial: <filter>
UEFI: LENOVO v: JUCN59WW date: 03/15/2023
ID-1: BAT0 charge: 60.9 Wh (79.0%) condition: 77.1/80.0 Wh (96.4%)
volts: 16.5 min: 15.4 model: BYD L21B4PC0 type: Li-poly serial: <filter>
status: not charging cycles: 91
Info: model: AMD Ryzen 7 6800H with Radeon Graphics socket: FP7 bits: 64
type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check built: 2022
process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x44 (68) stepping: 1
microcode: 0xA404102
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1013 high: 3178 min/max: 400/4785 base/boost: 3200/4750
scaling: driver: amd-pstate-epp governor: powersave volts: 1.2 V
ext-clock: 100 MHz cores: 1: 400 2: 1397 3: 400 4: 400 5: 1484 6: 400
7: 3178 8: 400 9: 1397 10: 400 11: 400 12: 400 13: 1397 14: 400 15: 2368
16: 1397 bogomips: 102206
Device-1: NVIDIA GA104M [Geforce RTX 3070 Ti Laptop GPU] vendor: Lenovo
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:24e0
Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, DP-5, DP-6 bus-ID: 34:00.0 chip-ID: 1002:1681
class-ID: 0300 temp: 46.0 C
Display: server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia dri: radeonsi
Screen-1: 0 s-res: 2560x1600 s-dpi: 75 s-size: 869x543mm (34.21x21.38")
s-diag: 1025mm (40.34")
Monitor-1: eDP-1 mapped: eDP-1-0 model: BOE Display 0x0a9b built: 2020
res: 2560x1600 hz: 165 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46")
diag: 406mm (16") ratio: 16:10 modes: max: 2560x1600 min: 640x480
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 545.29.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti Laptop
GPU/PCIe/SSE2 memory: 7.81 GiB
API: Vulkan v: 1.3.269 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1681 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 Ti Laptop GPU driver: nvidia v: 545.29.02
device-ID: 10de:24e0 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
bus-ID: 34:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 34:00.6
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.84 status: n/a (root, process) with:
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0489:e0d8
Local Storage: total: 953.87 GiB used: 71.04 GiB (7.4%)
model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: CL1QGXA7 temp: 41.9 C scheme: GPT
SMART: yes health: PASSED on: 79d 18h cycles: 23,763
read-units: 81,807,705 [41.8 TB] written-units: 78,330,638 [40.1 TB]
ID-1: / raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
used: 70.98 GiB (60.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 60.5 MiB (63.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 14.82 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 61.6 C mobo: 44.0 C
GPU: device: nvidia screen: :0.0 temp: 47 C device: amdgpu temp: 48.0 C
Processes: 401 Uptime: 2m wakeups: 0 Memory: total: 16 GiB note: est.
available: 14.82 GiB used: 6.06 GiB (40.9%) Init: systemd v: 254
pm: pacman pkgs: 1620 libs: 419 tools: octopi,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.2.15 running-in: kitty inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-09-12
Last full system update: 2023-11-14
Windows dual boot: Yes
As far as I know, I’m using proper drivers for both Nvidia GPU and AMD. I am using Nvidia Prime. Any help is acceptable!
