System shuts down on hibernate
I've enabled hibernate during the Garuda install. But when I put my machine to hibernate it switches off instead(guessing from the fact that the power indicator turns off and the system doesnot respond to mouse-clicks, keyboard-clicks). So the only way to start it is by pressing power button which starts in a fresh state.
Kernel: 6.1.20-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=c1dddf1a-6696-45f9-8627-5b3b311de43a rw rootflags=subvol=@
resume=UUID=bb22e8f1-2624-476a-9715-cf2139919f7c loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Nitro AN515-56 v: V1.08
Mobo: TGL model: Scala_TLM v: V1.08 serial: <superuser required>
UEFI: Insyde v: 1.08 date: 12/02/2021
ID-1: BAT1 charge: 32.2 Wh (64.1%) condition: 50.2/57.5 Wh (87.2%)
volts: 16.5 min: 15.4 model: LGC AP18E8M type: Li-ion serial: <filter>
status: charging cycles: 78
Info: model: 11th Gen Intel Core i5-11300H bits: 64 type: MT MCP
microcode: 0xA6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2073 high: 3100 min/max: 400/4400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3100 2: 1034 3: 1170
4: 3100 5: 3100 6: 960 7: 1027 8: 3100 bogomips: 49784
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.1
process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: DP-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 525.89.02
alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
chip-ID: 10de:1f9d class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 3-8:3
chip-ID: 0408:a061 class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Device-2: NVIDIA vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound API: ALSA v: k6.1.20-1-lts running: yes
Device-1: Intel Wi-Fi 6 AX201 vendor: Rivet Networks driver: iwlwifi
v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
port: 3000 bus-ID: 0000:2c:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF: enp44s0 state: down mac: <filter>
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
address: <filter>
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 1.38 TiB used: 46.86 GiB (3.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM512GD3JX016N
lanes: 4 type: SSD serial: <filter> rev: 41020C20 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
used: 29.65 GiB (6.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-4: /var/log raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.68 GiB size: 459.68 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 254 Uptime: 15m wakeups: 16384 Memory: 15.42 GiB
used: 3.26 GiB (21.1%) Init: systemd v: 253 default: graphical
pkgs: 1273 libs: 329 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date:     2023-03-15
Last full system update: 2023-03-21
I don't know if this one has any relation to the problem or not but there is one thing to add. I am using ibt=off in the boot-options because without that the system doesn't boot.
How are you performing the hibernate process?
On the lock screen there is an option called hibernate. I am clicking on that.
Is there an option to SUSPEND also?
If yes, does it also shutdown?
Just trying to narrow down if this is only related to Hibernate or not.
If I’m correct, this indicates you didn’t actually allocate disk space for swap during install, or it didn’t go as planned.
There is a sleep option but sleep works fine.
Ok then are you able to validate what zoeruda is asking?
Sorry, I don't know how to validate it.
Should I do a reinstall?
No reinstall for now.
I am totally not familiar with Hibernation, but if I would need to be the first thing I'd try to understand is section 4 here Power management/Suspend and hibernate - ArchWiki (archlinux.org)
I am going through the link that you've given Power management/Suspend and hibernate - ArchWiki (archlinux.org).
The resume parameter mention in the section 4.3 is correctly present in the boot-options.
Section 4.1 specifies some things to make hibernate image smaller (which I think is not the concern for now).
And last one is Section 4.2 and I don't know how to check / modify the current hooks being used by the initramfs..
Garuda uses Dracut now, so to check what hooks are being used, run sudo lsinitrd /path/to/initramfs_or_uefi_image | less (image should be in your /boot folder) as suggested here: dracut - ArchWiki in the tips and tricks section.
If you don’t have the resume hook, look at the troubleshooting section further down the page to implement it.
However, unfortunately, I can’t guarantee that doing this will necessarily work for you, but it’s always worth a check just in case. I am also facing the same issue with shutting down instead of hibernating, and I have the resume hook as well. I’m a Qtile user now though, so idk whether I qualify to chime in here anymore :')
Hibernating used to work for me on my old setup with KDE (in fact it was safer than sleeping since i would get the mouse cursor on blank screen issue after waking from sleep sometimes), but I was using mkinitcpio and never tested it after I moved it to Dracut. The swap setup is basically identical to my current one, just ± a GB here and there. Both were made by the Garuda installer on the live ISO, and the KDE setup had hibernate working after I added the resume hook via mkinitpcio… I’ve been hibernating by directly running systemctl hibernate and hitting my power button, which is set to hibernate.
garuda-inxi from old setup where hibernate was working
  Kernel: 5.15.79-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=c9f99daa-f49a-4d9f-a961-e0361c675eed
    rw rootflags=subvol=@ splash rd.udev.log_priority=3 vt.global_cursor_default=0
    resume=UUID=8d72c892-6d9c-4514-b2d6-398dc499ca0c loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: Dell product: XPS 15 9560 v: N/A serial: <superuser required> Chassis:
    type: 10 serial: <superuser required>
  Mobo: Dell model: 05FFDN v: A00 serial: <superuser required> UEFI: Dell v: 1.24.0
    date: 08/10/2021
  ID-1: BAT0 charge: 26.7 Wh (32.3%) condition: 82.7/97.0 Wh (85.3%) volts: 11.2 min: 11.4
    model: LGC-LGC8.33 DELL 5XJ28 type: Li-ion serial: <filter> status: discharging
  Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake gen: core 7 level: v3
    note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
    microcode: 0xF0
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 900 min/max: 800/3800 scaling: driver: intel_pstate governor: powersave
    cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 bogomips: 44798
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel arch: Gen-9.5
    process: Intel 14nm built: 2016-20 ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:591b class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: nvidia v: 520.56.06
    alternate: nouveau,nvidia_drm non-free: 520.xx+ status: current (as of 2022-10) arch: Pascal
    code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
  Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-12:7
    chip-ID: 1bcf:2b95 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 compositor: kwin_x11 driver: X:
    loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 168 s-size: 580x326mm (22.83x12.83") s-diag: 665mm (26.19")
  Monitor-1: eDP-1 mapped: eDP1 model: Sharp 0x1476 built: 2016 res: 3840x2160 hz: 60 dpi: 279
    gamma: 1.2 size: 350x190mm (13.78x7.48") diag: 397mm (15.6") ratio: 16:9 modes: 3840x2160
  API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel HD Graphics 630 (KBL GT2)
    direct render: Yes
  Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
    chip-ID: 8086:a171 class-ID: 0403
  Sound API: ALSA v: k5.15.79-1-lts running: yes
  Sound Server-2: PipeWire v: 0.3.60 running: yes
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Rivet Networks
    Killer Wireless-n/a/ac 1535 driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 41.0 C
 Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
    chip-ID: 0cf3:e300 class-ID: e001
  Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 1 state: down bt-service: disabled
    rfk-block: hardware: no software: no address: N/A
  Local Storage: total: 476.94 GiB used: 587.04 GiB (123.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: KXG50ZNV512G NVMe 512GB
    size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: AADA4106 temp: 31.9 C scheme: GPT
  ID-1: / raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 10.2 MiB (3.4%) fs: vfat
  ID-3: /home raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%) fs: btrfs
  ID-4: /var/log raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%)
  ID-5: /var/tmp raw-size: 459.61 GiB size: 459.61 GiB (100.00%) used: 148.98 GiB (32.4%)
  ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 17.03 GiB used: 0 KiB (0.0%) priority: -2
  System Temperatures: cpu: 46.0 C pch: 43.5 C mobo: N/A
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 281 Uptime: 1h 30m wakeups: 3 Memory: 15.48 GiB used: 5.18 GiB (33.5%) Init: systemd
  v: 252 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1780
  libs: 500 tools: octopi,pamac,paru pm: appimage pkgs: 0 Client: shell wrapper v: 5.1.16-release
  inxi: 3.3.23
Garuda (2.6.9-1):
  System install date:     2022-10-19
  Last full system update: 2022-11-26
  Failed units:            systemd-vconsole-setup.service
Current garuda-inxi
  Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=e34775a9-3a44-4cad-b4a1-7a4688cda7b4
    resume=UUID=fca2f0b8-fe12-4de7-b5ff-de54fd42afbb loglevel=3 ibt=off nvidia_drm.modeset=1
  Desktop: Qtile v: 0.22.1 wm: LG3D vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
    date: 08/10/2021
  ID-1: BAT0 charge: 61.0 Wh (73.8%) condition: 82.7/97.0 Wh (85.3%) volts: 11.9 min: 11.4
    model: LGC-LGC8.33 DELL 5XJ28 type: Li-ion serial: <filter> status: not charging
    microcode: 0xF0
  Speed (MHz): avg: 3469 high: 3556 min/max: 800/3800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3488 2: 3400 3: 3444 4: 3556 5: 3556 6: 3421 7: 3479 8: 3415
    bogomips: 44798
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: nvidia v: 525.89.02
    alternate: nouveau,nvidia_drm non-free: 525.xx+ status: current (as of 2023-02) arch: Pascal
    code: GP10x process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
    gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
  Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-c4107 driver: X:
    loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: iris gpu: i915
  Screen-1: 0 s-res: 3840x2160 s-dpi: 185 s-size: 527x296mm (20.75x11.65") s-diag: 604mm (23.8")
  Monitor-1: eDP-1 model: Sharp 0x1476 built: 2016 res: 3840x2160 hz: 60 dpi: 282 gamma: 1.2
    size: 346x194mm (13.62x7.64") diag: 397mm (15.6") ratio: 16:9 modes: 3840x2160
  API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
    alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
    bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 38.0 C
  Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 476.94 GiB used: 512.67 GiB (107.5%)
    serial: <filter> rev: AADA4106 temp: 30.9 C scheme: GPT
  ID-1: / raw-size: 459.62 GiB size: 459.62 GiB (100.00%) used: 77.32 GiB (16.8%) fs: btrfs
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
  ID-3: /home raw-size: 459.62 GiB size: 459.62 GiB (100.00%) used: 77.32 GiB (16.8%) fs: btrfs
  ID-4: /var/log raw-size: 459.62 GiB size: 459.62 GiB (100.00%) used: 77.32 GiB (16.8%)
  ID-5: /var/tmp raw-size: 459.62 GiB size: 459.62 GiB (100.00%) used: 77.32 GiB (16.8%)
  ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
  ID-2: swap-2 type: partition size: 17.02 GiB used: 0 KiB (0.0%) priority: -2
  System Temperatures: cpu: 45.0 C pch: 45.5 C mobo: 40.0 C
  Fan Speeds (RPM): cpu: 2509 fan-2: 2520
  Processes: 276 Uptime: 14h 51m wakeups: 2158 Memory: 15.47 GiB used: 4.49 GiB (29.0%)
  Init: systemd v: 253 default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1458 libs: 371 tools: paru Client: shell wrapper v: 5.1.16-release
  inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2023-03-19
  Failed units:            power.service systemd-vconsole-setup.service
I’ll also chuck in some other things that may be worth checking, as they’re related to this issue afaik.
Current /etc/systemd/sleep.conf
Output of lsinitrd
Current /etc/systemd/logind.conf
Current /etc/default/grub
On another note, this is normal btw :slight_smile: a hibernating machine generally looks like it’s shut off - the power button light turns off for most machines. Most of them don’t respond to key presses - that is the case if the machine is sleeping (suspend to ram).
What matters is whether your last session still comes back the way it was before. Iirc, you should land back on a lock screen, not the SDDM login manager.
oops :melting_face:.
Right now the system does not resume from its old state. It is starting from a fresh login screen.
I've added the following lines to the resume-from-hibernate.conf
[🔴] × cat /etc/dracut.conf.d/resume-from-hibernate.conf                                               (base)
File: /etc/dracut.conf.d/resume-from-hibernate.conf
add_dracutmodules+=" resume "
and then regenerated the linux image using the command sudo dracut --hostonly --no-hostonly-cmdline /boot/initramfs-linux-lts.img --force and then tried to boot from linux-lts image.. But then the system got struck at the boot screen itself :sob:
Can you try booting off from the fallback image from GRUB menu?
Or you can boot from a Snapshot and restore it prior to the change. You can also manually take a snapshot when you know you are about to make changes to the root subvolume so you can revert EXACTLY to where it was before.
I am able to boot into my system currently using linux-zen image. I've only used linux-lts image for testing if hibernate is working with it because older posts regarding hibernate issue suggested trying out things with lts image
Hmm, maybe try that again on the boot image that has the kernel version numbers on it. That is what is normally generated by Dracut when you run # dracut -f and is booted from GRUB.
Hopefully it’ll let you boot back into the LTS image - if not, snapshot time or Zen time I guess :person_shrugging:
Btw, by not being able to boot I’m assuming it was a kernel panic? This is a worthwhile link to save about Dracut - I had it happen with a fresh installation of my Fedora box lmao. The commands in there are good for if you nuked your image somehow.
Not sure… I was not able to enter the textual output screen on pressing ESC key… So I powered off the laptop and rebooted to zen image.
Before I upgraded to version 6.2.2-zen1-1-zen, hibernate used to work for me. I am not sure what the version number was.
I've used the following command to downgrade to a sufficiently older kernel
sudo pacman -U https://archive.archlinux.org/packages/l/linux-zen/linux-zen-5.16.13.zen1-1-x86_64.pkg.tar
.zst https://archive.archlinux.org/packages/l/linux-zen-headers/linux-zen-headers-5.16.13.zen1-1-x86_64.pkg.ta
r.zst
And now hibernate works without any flaw!
