GenXI
November 12, 2022, 6:59am
1
Kernel: 5.15.77-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=dd3b181e-c334-4d28-8cdd-b1a1db3e6edc rw rootflags=subvol=@
resume=UUID=d4e754ff-8b48-4291-8a95-9edf974158a9 loglevel=3
Desktop: LXQt v: 1.2.0 tk: Qt v: 5.15.7 info: cairo-dock, lxqt-panel
Type: Convertible System: LENOVO product: 81EM v: Lenovo ideapad FLEX
6-14IKB serial: <superuser required> Chassis: type: 31 v: Lenovo ideapad
FLEX 6-14IKB serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI-[Legacy]: LENOVO v: 7QCN46WW
date: 11/26/2020
ID-1: BAT0 charge: 34.7 Wh (100.0%) condition: 34.7/45.5 Wh (76.2%)
volts: 8.4 min: 7.7 model: CPT-COS L17C4PB0 type: Li-poly serial: <filter>
status: full
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 802 high: 816 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 816 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 28800
vulnerable
prctl and seccomp
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:4 chip-ID: 13d3:56b2 class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0x403d built: 2016 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
missing.
Sound API: ALSA v: k5.15.77-1-lts running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Lenovo ThinkPad E595 driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-7:3 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 119.24 GiB used: 79.59 GiB (66.7%)
model: MZVLW128HEGR-000L2 size: 119.24 GiB block-size: physical: 512 B
rev: 4L1QCXB7 temp: 30.9 C scheme: MBR
ID-1: / raw-size: 81.14 GiB size: 81.14 GiB (100.00%)
used: 79.59 GiB (98.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 81.14 GiB size: 81.14 GiB (100.00%)
ID-3: /var/log raw-size: 81.14 GiB size: 81.14 GiB (100.00%)
ID-4: /var/tmp raw-size: 81.14 GiB size: 81.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 40.0 C pch: 38.5 C mobo: N/A
Processes: 239 Uptime: 8m wakeups: 3 Memory: 7.55 GiB used: 1.9 GiB (25.1%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1491 libs: 378
tools: octopi,paru pm: rpm pkgs: 0 Shell: Bash v: 5.1.16
running-in: qterminal inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-10-22
Last full system update: 2022-11-09
Okay so this starts with Virtual Box malfunctioning. My Kali system threw an error. So I removed it "deleting all the files." Try to reload it and was missing part of the file needed. So I trash the files. Try to extract the exact same files from the zip files and that throws an error while extracting. Downloaded Kali again trashing the original zip and tried to extract again still got the same error. So I try to restore a snapshot and get that done no problem. Once I reboot, I get stuck at:
Loading Linux lts <----- I think that's what it is but to be sure it's not loading zen it's loading the older kernel like it's suppose to I just don't remember the spelling.
loading initial ramdisk
I rebooted a few times stuck each time at that loading sequence above.
Try to load in recovery mode. That worked. Didn't do anything just rebooted crossed the fingers and finally got to my desktop again. Tried to run garuda-update
[Output in next post too long to post in this one]
Kwin also crashed in the process
And now I'm here.
GenXI
November 12, 2022, 7:01am
2
[genxi@genxi-81em ~]$ garuda-update
[sudo] password for genxi:
garuda 95.6 KiB 38.8 KiB/s 00:02 [---------------------------------------] 100%
core 157.7 KiB 166 KiB/s 00:01 [---------------------------------------] 100%
extra.db failed to download
community.db failed to download
multilib 167.4 KiB 131 KiB/s 00:01 [---------------------------------------] 100%
chaotic-aur 1970.9 KiB 758 KiB/s 00:03 [---------------------------------------] 100%
error: failed retrieving file 'extra.db' from arch.mirror.constant.com : Failure writing output to destination
error: failed retrieving file 'community.db' from arch.mirror.constant.com : Failure writing output to destination
error: failed retrieving file 'extra.db' from ftp.wrz.de : Failure writing output to destination
error: failed retrieving file 'extra.db' from ftp-stud.hs-esslingen.de : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from geo-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'community.db' from ftp.wrz.de : Failure writing output to destination
error: failed retrieving file 'extra.db' from archlinux.mirror.rafal.ca : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from cdn-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'community.db' from ftp-stud.hs-esslingen.de : Failure writing output to destination
error: failed retrieving file 'extra.db' from archmirror.it : Failure writing output to destination
error: failed retrieving file 'community.db' from archlinux.mirror.rafal.ca : Failure writing output to destination
error: failed retrieving file 'community.db' from archmirror.it : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from cdn-cn-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.hackingand.coffee : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.hackingand.coffee : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.xenyth.net : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.xenyth.net : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.archlinux.cl : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.archlinux.cl : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.osbeck.com : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.osbeck.com : Failure writing output to destination
error: failed retrieving file 'extra.db' from mnvoip.mm.fcix.net : Failure writing output to destination
error: failed retrieving file 'community.db' from mnvoip.mm.fcix.net : Failure writing output to destination
error: failed retrieving file 'extra.db' from arch.jensgutermuth.de : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.ams1.nl.leaseweb.net : Failure writing output to destination
error: failed retrieving file 'community.db' from arch.jensgutermuth.de : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.0x.sg : Failure writing output to destination
error: failed retrieving file 'extra.db' from forksystems.mm.fcix.net : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.mangohost.net : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.theash.xyz : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from au-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirrors.xtom.nl : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirrors.xtom.de : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.ams1.nl.leaseweb.net : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from au-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.0x.sg : Failure writing output to destination
error: failed retrieving file 'community.db' from forksystems.mm.fcix.net : Failure writing output to destination
error: failed retrieving file 'extra.db' from mirror.lty.me : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from br-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.mangohost.net : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.theash.xyz : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.xtom.nl : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.xtom.de : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.lty.me : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from br-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from br-3-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from bg-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from ca-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from ca-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from ca-3-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from cl-1-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from cl-2-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from fr-1-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from fr-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from fr-3-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from de-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from de-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from de-3-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from de-4-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from de-5-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from de-6-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from in-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from in-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from in-3-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from in-4-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from in-5-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from in-6-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from jp-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from jp-1-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from jp-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from jp-3-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from kr-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from kr-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from kr-3-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from es-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from es-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from ae-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from ae-2-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from uk-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from uk-1-mirror.chaotic.cx : The requested URL returned error: 404
error: failed to synchronize all databases (unexpected error)
chaotic-aur 1970.9 KiB 696 KiB/s 00:03 [#######################################] 100%
warning: downgrading package garuda-update (3.0.7-1 => 2.5.2-1)
Packages (1) garuda-update-2.5.2-1
Total Download Size: 0.01 MiB
Total Installed Size: 0.01 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
garuda-update-2.5.2-1-any 7.6 KiB 8.90 KiB/s 00:01 [#######################################] 100%
(1/1) checking keys in keyring [#######################################] 100%
(1/1) checking package integrity [#######################################] 100%
(1/1) loading package files [#######################################] 100%
(1/1) checking for file conflicts [#######################################] 100%
snapper snapshots skipped
(1/1) downgrading garuda-update
GenXI
November 12, 2022, 7:02am
3
(1/6) Arming ConditionNeedsUpdate...
(2/6) Foreign/AUR package notification
balena-etcher 1.7.9-1
koreader-appimage 2022.08-1
lector 0.5.1-1
libusrsctp-git 0.9.5.0.r178.g8e12cd9-1
lrexlib-pcre5.1 2.9.0-2
lua-yajl 2.0-2
lua51-lcf 5.1-3
lua51-sql-sqlite 2.3.0-4
luazip5.1 1.2.7-1
lxqt-kcm-integration-extra-git r10.7c36c28-1
lxqt-kwin-desktop-git 0.17.0-1
mudlet 4.16.0-1
psi-plus 1.5.1543-1
shortwave 1:3.0.0-2
streamlink-twitch-gui 2.2.0-1
(3/6) Orphaned package notification...
boost 1.80.0-3
geocode-glib 3.26.4-2
luarocks 3.9.1-1
ninja 1.11.1-1
rest 0.8.1+r4+ge5ee6ef-1
(4/6) Checking for .pacnew and .pacsave files...
(5/6) Performing snapper post snapshots for the following configurations...
(6/6) Syncing all file systems...
garuda is up to date
core is up to date
extra 1760.9 KiB 526 KiB/s 00:03 [---------------------------------------] 100%
error: failed to synchronize all databases (download library error)
chaotic-aur 1970.9 KiB 724 KiB/s 00:03 [#######################################] 100%
warning: garuda-update-2.5.2-1 is up to date -- skipping
there is nothing to do
core is up to date
extra is up to date
multilib is up to date
chaotic-aur is up to date
chaotic-aur.db failed to download
error: failed retrieving file 'chaotic-aur.db' from garudalinux.org : Failure writing output to destination
Packages (1) garuda-update-3.1.3-1
Total Installed Size: 0.02 MiB
error: Partition /var/cache too full: 5124 blocks needed, 1 blocks free
error: failed to commit transaction (not enough free disk space)
grep: warning: stray \ before /
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda 95.6 KiB 17.9 KiB/s 00:05 [---------------------------------------] 100%
core 157.7 KiB 133 KiB/s 00:01 [---------------------------------------] 100%
extra 1760.9 KiB 247 KiB/s 00:07 [---------------------------------------] 100%
multilib 167.4 KiB 204 KiB/s 00:01 [---------------------------------------] 100%
error: failed retrieving file 'extra.db' from ftp.sudhip.com : Failure writing output to destination
error: failed retrieving file 'community.db' from ftp.sudhip.com : Failure writing output to destination
error: failed retrieving file 'community.db' from arch.jsc.mx : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.csclub.uwaterloo.ca : Failure writing output to destination
error: failed retrieving file 'community.db' from br.mirror.archlinux-br.org : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.init7.net : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.cedia.org.ec : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.anquan.cl : Failure writing output to destination
error: failed retrieving file 'community.db' from lysakermoen.com : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.surf : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.sahil.world : Failure writing output to destination
error: failed retrieving file 'community.db' from arch.midov.pl : Failure writing output to destination
error: failed retrieving file 'community.db' from nova.quantum-mirror.hu : Failure writing output to destination
error: failed retrieving file 'community.db' from ftp.icm.edu.pl : Failure writing output to destination
error: failed retrieving file 'community.db' from archlinux.koyanet.lv : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.dkm.cz : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.librelabucm.org : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.xmission.com : Failure writing output to destination
error: failed retrieving file 'community.db' from arch.mirrors.lavatech.top : Failure writing output to destination
error: failed retrieving file 'community.db' from pkg.adfinis.com : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.radwebhosting.com : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.sg.gs : Failure writing output to destination
error: failed retrieving file 'community.db' from www.mirrorservice.org : Failure writing output to destination
error: failed retrieving file 'community.db' from arch.lucassymons.net : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.gigenet.com : Failure writing output to destination
error: failed retrieving file 'community.db' from mirroir.labhouse.fr : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.ette.biz : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.phx1.us.spryservers.net : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.moson.org : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.pit.teraswitch.com : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.xtom.ee : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.celianvdb.fr : Failure writing output to destination
error: failed retrieving file 'community.db' from ftp.uni-hannover.de : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror2.evolution-host.com : Failure writing output to destination
error: failed retrieving file 'community.db' from mirrors.manchester.m247.com : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.netcologne.de : Failure writing output to destination
error: failed retrieving file 'community.db' from archlinux.datagr.am : Failure writing output to destination
error: failed retrieving file 'community.db' from mirror.fcix.net : Failure writing output to destination
error: failed retrieving file 'community.db' from archlinux.honkgong.info : Failure writing output to destination
error: failed retrieving file 'community.db' from archlinux.mirror.server24.net : Failure writing output to destination
error: failed retrieving file 'community.db' from ord.mirror.rackspace.com : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from uk-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from uk-3-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from us-az-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-az-1-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from us-az-2-mirror.chaotic.cx : The requested URL returned error: 404
error: failed retrieving file 'chaotic-aur.db' from us-fl-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-mi-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-ny-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-tx-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-ut-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-va-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-va-2-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-va-3-mirror.chaotic.cx : Failure writing output to destination
error: failed retrieving file 'chaotic-aur.db' from us-va-4-mirror.chaotic.cx : The requested URL returned error: 404
error: failed to synchronize all databases (failed to retrieve some files)
Failed to update mirrorlist
core is up to date
extra is up to date
error: Partition /var/cache too full: 5124 blocks needed, 231 blocks free
--> Applying keyring updates before starting full system update..
warning: chaotic-keyring-20220803-1 is up to date -- skipping
warning: garuda-hotfixes-1.1.2-1 is up to date -- skipping
resolving dependencies...
Packages (1) archlinux-keyring-20221110-1
Total Installed Size: 1.57 MiB
Net Upgrade Size: 0.01 MiB
(1/1) checking keys in keyring [---------------------------------------] 100%
(1/1) checking package integrity [---------------------------------------] 100%
(1/1) loading package files [---------------------------------------] 100%
(1/1) checking for file conflicts [---------------------------------------] 100%
(1/1) checking available disk space [---------------------------------------] 100%
error: Partition / too full: 5122 blocks needed, 231 blocks free
error: not enough free disk space
filo
November 12, 2022, 7:53am
4
First of all, I think you are running low on disk space.
Any chance to clean up and retry?
GenXI
November 12, 2022, 8:40am
5
Well I feel silly. So that fixed just about everything. On a reboot it still hung on loading linux-lts plugging it in got it to boot though. Any way to refresh my kernel? Also when Kwin crashed it wiped out a section of the bottom of my screen. After a reboot it's still not loading a section of the bottom of my screen. Still have access to the dock and start bar (sorry windows) any suggestions?
filo
November 12, 2022, 8:44am
6
Open KDE settings and search for compositor.
If the relevant settings page mentions it is crashed, confirm to reset it.
Not sure what you mean about the kernel, sorry.
GenXI
November 12, 2022, 8:51am
7
So I restored defaults and for some reason at some point, I sure don't remember doing this, but it was set to not start on startup. Once I applied the defaults in compositor everything looks normal again. Thanks that'll about do it I think. I think I see a reason now to maybe set up a conky and monitor my drivespace LOL
TNE
November 13, 2022, 8:03am
8
Maybe lowering the amount of snapshots you keep around could be helpful in your case, with so little space available.
system
Closed
November 15, 2022, 8:04am
9
