I also thought of that but the thing is I did btrfs check–repair as the first as said by the dev…
I later got to the thought of all the above btrfs rescue zero-log etc
Actually on gnome disk utility the size of the partition is 92 gigs and on other places its 85 gigs, I used kde partition manager and system worked for a bit then as said above after 3-4 boots in 5 hours system borked.
Edit: Kde used GiB and gnome uses GB, i didnt use gnome at all, I used Kde partition manager only.
@SGS@jonathon@Bro@Grimy1928@BluishHumility When I chrooted I went into my home dir and there were some of my files (very less but each folder had some), can I run
btrfs rescue chunk-recover ?
Did you disable quick startup in the Windows power management menu?
Power & Sleep → Additional Power Settings → Choose what the power buttons do → Change settings that are currently unavailable → uncheck “Turn on fast startup”
Unfortunately I didn't... It was a mess. Didn't have an external storage and just bought one after the incident
And i just didn't back it up into my existing internal storage from live usb before btrfs check--repair
