I fell asleep with my computer running, my controller cord was resting on the screenshot button and it opened spectacle a million times, and a ton of notifications for blocking memory overuse was up. The system was froze so I force restarted it with the power button now I’m stuck on a grey screen when I log in.
The garuda data file is unavailable as I cannot access the system.
filo
March 19, 2025, 5:57pm
2
Can you switch to a tty (e.g. CTRL+ALT+F3)? If so, can you log in? This would suggest a KDE plasma problem, or maybe SDDM.
If you use x11, check this suggestion:
If none of the above helps, you could try booting from a live USB, chroot into your system and start checking the status. Maybe you have a disk space issue also.
Did you perform an update without rebooting before this? Or any other important action?
Well I used a different kernel and was able to get in, I updated the system then rebooted, and it seems to be all working like normal. The kernel that was freezing up is no longer doing that.
I’m still not entirely sure why it was happening or what to mark as the solution
system
Closed
March 21, 2025, 8:45pm
4
tbg
March 21, 2025, 9:00pm
5
Testing out alternate kernels is a primary troubleshooting step. It is one of the first things that should be tested whenever a serious issue occurs.
Thanks for posting back with your solution. However, it would be far more useful to others if you provide more information.
One of the reasons we ask for a garuda-inxi
output on every help request is so that we know the hardware in use. This not only helps forum assistants diagnose problems, it also lets other users know if their problem might be occurring because they own similar hardware. The inxi output is essential forum information for us and others to learn how a problem can be resolved.
Without knowing which kernel you were using originally, and which kernel resolved your issue, your given solution is far less useful to others experiencing a similar problem. Please at a minimum provide this information, so that others know which kernel to try and avoid a bunch of wasted time and bandwidth downloading and testing various different kernels.
I’m glad to see you found a solution to your problem, but in the future please provide more information so that others may benefit from what you learned.
Ok, I’m back. Originally I was using Linux-zen then switched to Linux-lts which let me log in. Linux-zen works as usual now. I forgot about switching to TTY 2 so at the time I thought it was totally unavailable to get the garuda-inxi
I would have usually provided as much information as possible but I only remembered to get back while at work and on my phone plus it was a weird day overall.
anyway, here’s the garuda-inxi:
╭─zoey@CUMMY in ~
╰─λ garuda-inxi
root=UUID=7b56fc96-0e19-473d-badd-73a065550c34 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: MPG B550 GAMING EDGE WIFI (MS-7C91)
v: 1.0 serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.H0 date: 07/17/2024
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1734 min/max: 550/4651 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1734 2: 1734 3: 1734
4: 1734 5: 1734 6: 1734 7: 1734 8: 1734 9: 1734 10: 1734 11: 1734 12: 1734
bogomips: 88805
Device-1: Advanced Micro Devices [AMD/ATI] Navi 22 [Radeon RX 6700/6700
XT/6750 XT / 6800M/6850M XT] vendor: Tul / PowerColor Red Devil
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
off: HDMI-A-1 empty: DP-1,DP-3,Writeback-1 bus-ID: 2d:00.0
chip-ID: 1002:73df class-ID: 0300
s-diag: 777mm (30.58")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary model: ASUS VG32VQR
serial: <filter> built: 2021 res: mode: 2560x1440 hz: 165 scale: 100% (1)
dpi: 93 gamma: 1.2 size: 697x393mm (27.44x15.47") diag: 800mm (31.5")
ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 note: disabled model: Acer KA242Y
serial: <filter> built: 2021 res: 2560x1440 dpi: 93 gamma: 1.2
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2-arch1.2
navi22 LLVM 19.1.7 DRM 3.61 6.13.8-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
API: Vulkan v: 1.4.309 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: N/A device-ID: 1002:73df
bus-ID: 2d:00.1 chip-ID: 1002:ab28 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 29:00.0
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:6 chip-ID: 8087:0032
Local Storage: total: 14.81 TiB used: 5.07 TiB (34.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1006 size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS2 temp: 36.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST14000NM001G-2KJ103
size: 12.73 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SN02 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
ID-4: /dev/sdc maj-min: 8:32 vendor: SanDisk model: Ultra size: 28.64 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.13 TiB (62.3%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
used: 1.13 TiB (62.3%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 51.5 C mobo: N/A gpu: amdgpu temp: 42.0 C
mem: 38.0 C
Memory: total: 16 GiB available: 15.54 GiB used: 6.34 GiB (40.8%)
Processes: 377 Power: uptime: 8m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2064 libs: 593 tools: octopi,paru,yay
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish
v: 4.0.1 running-in: konsole inxi: 3.3.37
System install date: 2023-12-16
Last full system update: 2025-03-25
system
Closed
March 31, 2025, 8:07am
8
