Hello everyone, i need help.System freezes randomly, it happens right after the boot, even on a login screen, after some ours, but NEVER when some game is running.
This is garuda-inxi
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=fdf04799-bd3a-43cc-9201-22338b358559 rw [email protected]
resume=UUID=489310f4-be41-444c-9b27-634c56e27576 loglevel=3 ibt=off
Desktop: Cinnamon v: 5.6.4 tk: GTK v: 3.24.35 wm: muffin vt: 7 dm: LightDM
v: 1.32.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4901
date: 07/25/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 2434 high: 3390 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3390 2: 2200
3: 2200 4: 2200 5: 2854 6: 2835 7: 2195 8: 2193 9: 2196 10: 2200 11: 2200
12: 2857 13: 2200 14: 2184 15: 2850 16: 2192 bogomips: 121367
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2 empty: DP-1,DP-3,HDMI-A-1 bus-ID: 0c:00.0
chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
Monitor-1: DP-2 mapped: DisplayPort-1 model: LG (GoldStar) MP59G
serial: <filter> built: 2016 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 690mm (27.2") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 14.0.6 DRM 3.48 6.0.12-zen1-1-zen) direct render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 1002:ab28
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Local Storage: total: 1.12 TiB used: 93 GiB (8.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: XPG GAMMIX S5
lanes: 4 type: SSD serial: <filter> rev: VC0S032V temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 480GB
size: 447.14 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500DM002-1BD142
type: HDD rpm: 7200 serial: <filter> rev: KC48 scheme: MBR
ID-1: / raw-size: 203.8 GiB size: 203.8 GiB (100.00%) used: 93 GiB (45.6%)
ID-3: /home raw-size: 203.8 GiB size: 203.8 GiB (100.00%)
used: 93 GiB (45.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 203.8 GiB size: 203.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 203.8 GiB size: 203.8 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: 33.0 C gpu: amdgpu temp: 32.0 C
mem: 30.0 C
Fan Speeds (RPM): cpu: 658 case-1: 617 case-2: 0 case-3: 662 gpu: amdgpu
fan: 0
Power: 12v: 9.92 5v: N/A 3.3v: N/A vbat: 3.18 gpu: amdgpu watts: 7.00
Processes: 394 Uptime: 16m wakeups: 0 Memory: 31.24 GiB
used: 5.19 GiB (16.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1226
libs: 342 tools: paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.24
Garuda (2.6.10-1):
System install date: 2022-12-01
Last full system update: 2022-12-13
I am receiving errors such as-
nvme nvme0: failed to set APST feature (2)
ACPI Error: Aborting method \_SB.PCI0.GPP2.PTXH.RHUB.POT4._PLD due to previous error (AE_AML_UNINITIALIZED_ELEMENT) (20220331/psparse-529)
gkr-pam: unable to locate daemon control file
kvm: support for 'kvm_amd' disabled by bios
Thank you
