System freezes at random for a few weeks now
Hi,
I'm facing random system freezes for a few weeks know. Hoped it would resolve after a round of updates but it didn't after 3 or 4 kernel patch updates, nvidia driver patch updates and so on. So now I'm getting a bit lost what to do.
The freezes happen pretty much randomly. While gaming, working, internet browsing. Sometimes after 5min of uptime, other times after 7 hours. I cannot make out any pattern tbh.
The system runs find and stable on Windows booted from a separate hard drive, so I assume my hardware is ok.
I tried to use different Kernels. The LTS and Mainline one but my system won't boot with them. It always get's stuck (but not unresponsive to ctrl+alt+del).
Other than that, at around the same time, it started to happen that the background on my main monitor won't load and the context menu would not appear when right clicking. Not sure if that is even related but I wanted to mention, just in case. For context. I have a three monitor setup and this only happens on the primary one.
What can I do or provide to get closer to a solution for this?
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4bb2e92b-2c1f-429f-91b3-080acabf426b rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 quiet
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop Mobo: Micro-Star model: MEG X570 ACE (MS-7C35) v: 1.0
serial: <filter> BIOS: American Megatrends LLC. v: 1.D0 date: 01/22/2021
Info: model: AMD Ryzen 9 3900X socket: AM4 bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x71 (113) stepping: 0
microcode: 0x8701021
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3800 min/max: 2200/4672 boost: enabled
base/boost: 3800/4650 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3800 2: 3800 3: 3800 4: 3800
5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800
13: 3800 14: 3800 15: 3800 16: 3800 17: 3800 18: 3800 19: 3800 20: 3800
21: 3800 22: 3800 23: 3800 24: 3800 bogomips: 182409
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: Micro-Star MSI
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0
chip-ID: 10de:2206 class-ID: 0300
Device-2: Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 6-4:2
chip-ID: 046d:0893 class-ID: 0300 serial: <filter>
Display: server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 7680x1571 s-dpi: 107 s-size: 1824x373mm (71.8x14.7")
s-diag: 1862mm (73.3")
Monitor-1: HDMI-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
Monitor-2: DP-0 res: 2560x1440 dpi: 55 size: 1193x336mm (47.0x13.2")
diag: 1239mm (48.8")
Monitor-3: DP-2 res: 2560x1440 dpi: 55 size: 1193x336mm (47.0x13.2")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:1aef
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
Device-3: Logitech G733 Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:2 chip-ID: 046d:0ab5
Device-4: Creative Sound BlasterX G5 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.1:4 chip-ID: 041e:3243
Device-5: Logitech StreamCam type: USB
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: e000 bus-ID: 26:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp38s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 28:00.0
chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-47e1368c669a state: down mac: <filter>
IF-ID-2: br-5dca3a391649 state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
bus-ID: 1-4:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.82 TiB used: 429.81 GiB (23.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Corsair model: Force MP600
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: EGFM11.3
temp: 45.9 C scheme: MBR
SMART: yes health: PASSED on: 289d 7h cycles: 543
read-units: 27,616,822 [14.1 TB] written-units: 255,463,339 [130 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: Force MP600
temp: 43.9 C scheme: GPT
SMART: yes health: PASSED on: 289d 5h cycles: 544
read-units: 6,806,809 [3.48 TB] written-units: 6,120,654 [3.13 TB]
used: 429.81 GiB (46.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
maj-min: 259:2
ID-1: swap-1 type: zram size: 31.33 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 51 C
Processes: 475 Uptime: 6m wakeups: 0 Memory: 31.33 GiB
used: 5.17 GiB (16.5%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1683 pacman: 1671 lib: 393 flatpak: 4 snap: 8
Shell: Bash (sudo) v: 5.1.12 running-in: konsole inxi: 3.3.11
Test the linux and linux-hardened kernels as well.
Is your bios up to date?
Check that all ram and cables are seated properly.
Perform a btrfs balance.
I have also found flaky pre-failure hard drives to be a cause of lockups in the past. Even though a drive passes testing it can still cause problems. Disconnect any attached drives except your boot drive.
I tired linux already. Won't boot. Simply gets stuck and won't continue like the other alternative kernels. No idea what to do in that case tbh.
Windows runs fine for multiple days now. Drive is nvme so there is no cable and it's securely screwed in.
Already tried btrfs balance as suggested in a similar thread. Ran through find, but didn't change anything.
I've updated my bios now and will see how it goes and report back in a few days.
Thanks for your suggestions.
Sadly the bios update didn't solve the issue. I just experienced a system freeze again.
Are there any other steps to do switch kernels other than installing the kernel in the managment UI and choosing it in grub?
Try linux-next-git to see if it will boot properly for you. It seems very strange that other developmental kernels will not boot on your modern hardware.
I would try searching on the web for recent freezing issues with Ryzen 9 computers.
I would also disconnect all but your main monitor and all peripherals like USB hubs, USB Hard drives, printers, web cams, etc etc as a test to see if the freezes still occur.
Also be sure to run the full ram test just to be sure RAM is not an issue. BTW, just because some hardware works without major issues on Windows does not guarantee that the issue is not related to your hardware. Linux can react very differently with subpar hardware than Windows at times.
Good luck, and Merry Christmas to you.
