System freeze with a TP-Link Archer T3U [Realtek RTL8812BU]
Hello Garuda users.
I'm unable to use my network usb adapter because after 10 seconds that I plugged it my system become unresponsive until I unplug it.
Kernel: 6.0.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b4dbbdd6-a7b3-4e98-90e2-b48cebb423e6 rw [email protected]
loglevel=3 ibt=off
Type: Desktop System: Micro-Star product: MS-7C51 v: 1.0
Mobo: Micro-Star model: A320M-A PRO (MS-7C51) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.30
date: 11/08/2019
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3755 high: 3775 min/max: 1550/3400 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3763 2: 3684
3: 3775 4: 3774 5: 3774 6: 3697 7: 3773 8: 3773 9: 3767 10: 3773 11: 3774
12: 3742 bogomips: 81590
Device-1: NVIDIA TU116 [GeForce GTX 1660] vendor: PNY driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 520.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 29:00.0 chip-ID: 10de:2184 class-ID: 0300
Device-2: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-2:3 chip-ID: 05a3:9331 class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3360x1080 s-dpi: 89 s-size: 959x315mm (37.76x12.40")
s-diag: 1009mm (39.74")
Monitor-1: DP-1 pos: bottom-l res: 1440x900 dpi: 89
size: 410x260mm (16.14x10.24") diag: 485mm (19.11") modes: N/A
Monitor-2: HDMI-0 pos: primary,top-right res: 1920x1080 hz: 144 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
1660/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: PNY
driver: snd_hda_intel bus-ID: 5-2:3 v: kernel pcie: chip-ID: 05a3:9331
gen: 3 class-ID: 0102 serial: <filter> speed: 8 GT/s lanes: 16
bus-ID: 29:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: ARC Camera type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.0.11-zen1-1-zen running: yes
Device-1: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 01:00.0
chip-ID: 10ec:8179 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
lanes: 1 port: e000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: down mac: <filter>
Device-3: TP-Link Archer T3U [Realtek RTL8812BU] type: USB
driver: rtw_8822bu bus-ID: 1-6:4 chip-ID: 2357:012d class-ID: 0000
IF-ID-2: enp3s0f0u9c4i2 state: up speed: N/A duplex: N/A mac: <filter>
IF-ID-3: wlp3s0f0u6 state: N/A mac: N/A
Local Storage: total: 1.13 TiB used: 872.44 GiB (75.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
serial: <filter> rev: 00K0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: HDWD110
type: HDD rpm: 7200 serial: <filter> rev: A8R0 scheme: GPT
used: 29.53 GiB (13.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 15.57 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 51.9 C mobo: N/A gpu: nvidia temp: 43 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 38%
Processes: 323 Uptime: 13m wakeups: 1 Memory: 15.57 GiB
used: 4.08 GiB (26.2%) Init: systemd v: 252 default: graphical
pkgs: 1746 libs: 502 tools: octopi,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date:     2022-12-08
Last full system update: 2022-12-08
Is partially upgraded:   Yes
Failed units:            systemd-networkd-wait-online.service
[  791.658976] usb 1-6: new high-speed USB device number 4 using xhci_hcd
[  791.877241] usb 1-6: New USB device found, idVendor=2357, idProduct=012d, bcdDevice= 2.10
[  791.877247] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  791.877248] usb 1-6: Product: 802.11ac NIC
[  791.877250] usb 1-6: Manufacturer: Realtek
[  791.877251] usb 1-6: SerialNumber: 123456
[  791.933594] rtw_8822bu 1-6:1.0: Firmware version 27.2.0, H2C version 13
[  800.191515] usbcore: registered new interface driver rtw_8822bu
[  800.376706] usbcore: registered new interface driver rtl88x2bu
[  800.382995] audit: type=1130 audit(1670532988.291:216): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  800.384152] rtw_8822bu 1-6:1.0 wlp3s0f0u6: renamed from wlan0
[  804.108234] rtw_8822bu 1-6:1.0: reg 0x24, usbctrl_vendorreq failed with -110
[  805.132203] rtw_8822bu 1-6:1.0: reg 0x28, usbctrl_vendorreq failed with -110
[  805.388812] audit: type=1131 audit(1670532993.296:217): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  806.156271] rtw_8822bu 1-6:1.0: reg 0x808, usbctrl_vendorreq failed with -110
[  807.180155] rtw_8822bu 1-6:1.0: reg 0xc08, usbctrl_vendorreq failed with -110
[  813.539909] usb 1-6: USB disconnect, device number 4
[  814.351097] ------------[ cut here ]------------
[  814.351102] write RF mode table fail
[  814.351122] WARNING: CPU: 10 PID: 674 at drivers/net/wireless/realtek/rtw88/rtw8822b.c:814 rtw8822b_config_trx_mode.constprop.0+0x914/0x920 [rtw88_8822b]
[  814.351131] Modules linked in: 88x2bu(OE) rtw88_8822bu rtw88_usb rtw88_8822b rtw88_core tls cmac ccm snd_seq_dummy snd_hrtimer snd_seq qrtr squashfs loop ipheth bridge stp llc intel_rapl_msr intel_rapl_common edac_mce_amd uinput kvm_amd dm_multipath dm_mod kvm rtl8188ee nvidia_drm(POE) irqbypass rtl_pci crct10dif_pclmul nvidia_uvm(POE) ucsi_ccg nvidia_modeset(POE) rtlwifi crc32_pclmul typec_ucsi vfat polyval_clmulni fat typec snd_hda_codec_realtek polyval_generic joydev snd_hda_codec_generic gf128mul mousedev apple_mfi_fastcharge roles mac80211 ccp ledtrig_audio snd_hda_codec_hdmi ghash_clmulni_intel aesni_intel snd_hda_intel libarc4 snd_intel_dspcfg nvidia(POE) crypto_simd r8169 snd_intel_sdw_acpi cryptd realtek cfg80211 snd_usb_audio snd_hda_codec rapl mdio_devres sp5100_tco snd_hda_core snd_usbmidi_lib wmi_bmof usbhid libphy k10temp rfkill snd_hwdep i2c_piix4 i2c_nvidia_gpu snd_rawmidi uvcvideo videobuf2_vmalloc snd_seq_device videobuf2_memops gpio_amdpt snd_pcm videobuf2_v4l2
[  814.351175]  videobuf2_common gpio_generic acpi_cpufreq snd_timer mac_hid videodev snd mc soundcore crypto_user fuse zram bpf_preload ip_tables x_tables btrfs blake2b_generic libcrc32c crc32c_generic xor raid6_pq crc32c_intel xhci_pci wmi xhci_pci_renesas radeon amdgpu gpu_sched drm_ttm_helper i915 video drm_buddy ttm drm_display_helper cec intel_agp intel_gtt
[  814.351196] CPU: 10 PID: 674 Comm: NetworkManager Tainted: P           OE      6.0.11-zen1-1-zen #1 0a288298051c3bd94d33cc240947eaa0e3533145
[  814.351200] Hardware name: Micro-Star International Co., Ltd. MS-7C51/A320M-A PRO (MS-7C51), BIOS 1.30 11/08/2019
[  814.351202] RIP: 0010:rtw8822b_config_trx_mode.constprop.0+0x914/0x920 [rtw88_8822b]
[  814.351206] Code: 68 1a 0d c6 e8 26 72 ef c3 0f 0b 48 83 c4 18 5b 5d 41 5c 41 5d 41 5e 41 5f e9 8c 08 36 c448 c7 c7 b5 19 0d c6 e8 05 72 ef c3 <0f> 0b eb dd 0f 1f 84 00 00 00 00 00 f3 0f 1e fa 0f 1f 44 00 00 41
[  814.351207] RSP: 0018:ffffa7e5834cf530 EFLAGS: 00010282
[  814.351209] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000027
[  814.351210] RDX: ffff957dbeca1668 RSI: 0000000000000001 RDI: ffff957dbeca1660
[  814.351212] RBP: 0000000000000002 R08: 0000000000000001 R09: 00000000ffffffea
[  814.351212] R10: ffff957dcf24c680 R11: 0000000000000002 R12: 0000000000000003
[  814.351213] R13: 0000000000000000 R14: ffff957c22812080 R15: 0000000000000002
[  814.351214] FS:  00007fe36f0631c0(0000) GS:ffff957dbec80000(0000) knlGS:0000000000000000
[  814.351215] CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[  814.351216] CR2: 00001e1008612118 CR3: 000000010a994000 CR4: 00000000003506e0
[  814.351218] Call Trace:
[  814.351219]  <TASK>
[  814.351222]  rtw8822b_phy_set_param+0x1cd/0x4f0 [rtw88_8822b 1020dbd16facbb2ed3f3e3c47c606c89978073c6]
[  814.351227]  rtw_core_start+0xbd/0x200 [rtw88_core 1a6201d6dfa0fd2ee75a80bc8e5236e5081851a4]
[  814.351243]  rtw_ops_start+0x26/0x40 [rtw88_core 1a6201d6dfa0fd2ee75a80bc8e5236e5081851a4]
[  814.351253]  drv_start+0x42/0x100 [mac80211 a1e5959f432f9aeefb73b8ebf31e0925e5dcb02e]
[  814.351309]  ieee80211_do_open+0x3ef/0xa10 [mac80211 a1e5959f432f9aeefb73b8ebf31e0925e5dcb02e]
[  814.351340]  ieee80211_open+0x6a/0x90 [mac80211 a1e5959f432f9aeefb73b8ebf31e0925e5dcb02e]
[  814.351369]  __dev_open+0x12b/0x1f0
[  814.351374]  __dev_change_flags+0x26c/0x2f0
[  814.351376]  dev_change_flags+0x43/0x260
[  814.351377]  ? sk_filter_trim_cap+0x122/0x240
[  814.351380]  do_setlink+0x37c/0x1440
[  814.351382]  ? sock_def_readable+0x12/0x80
[  814.351384]  ? netlink_unicast+0x426/0x4f0
[  814.351387]  ? rtnl_getlink+0x37d/0x440
[  814.351389]  ? slab_post_alloc_hook.constprop.0+0x32/0x240
[  814.351392]  ? kmem_cache_alloc_trace+0x173/0x2f0
[  814.351394]  rtnl_newlink+0x617/0xb40
[  814.351397]  ? bpf_lsm_capset+0x10/0x10
[  814.351400]  ? security_capable+0x44/0x70
[  814.351402]  rtnetlink_rcv_msg+0x152/0x3c0
[  814.351403]  ? bpf_lsm_socket_shutdown+0x10/0x10
[  814.351406]  ? security_sock_rcv_skb+0x38/0x50
[  814.351409]  ? __skb_try_recv_datagram+0xd1/0x300
[  814.351412]  ? rtnl_calcit.isra.0+0x140/0x140
[  814.351413]  netlink_rcv_skb+0x55/0x100
[  814.351415]  netlink_unicast+0x306/0x4f0
[  814.351417]  netlink_sendmsg+0x250/0x4d0
[  814.351419]  sock_sendmsg+0x63/0x70
[  814.351422]  ____sys_sendmsg+0x267/0x2b0
[  814.351424]  __sys_sendmsg+0x1d9/0x2b0
[  814.351429]  do_syscall_64+0x5f/0x90
[  814.351432]  ? exit_to_user_mode_prepare+0x145/0x1d0
[  814.351437]  ? syscall_exit_to_user_mode+0x2c/0x1d0
[  814.351439]  ? do_syscall_64+0x6b/0x90
[  814.351440]  ? do_syscall_64+0x6b/0x90
[  814.351442]  ? syscall_exit_to_user_mode+0x2c/0x1d0
[  814.351443]  ? do_syscall_64+0x6b/0x90
[  814.351444]  entry_SYSCALL_64_after_hwframe+0x63/0xcd
[  814.351448] RIP: 0033:0x7fe36f780ddd
[  814.351450] Code: 28 89 54 24 1c 48 89 74 24 10 89 7c 24 08 e8 9a 8f f7 ff 8b 54 24 1c 48 8b 74 24 10 41 89c0 8b 7c 24 08 b8 2e 00 00 00 0f 05 <48> 3d 00 f0 ff ff 77 33 44 89 c7 48 89 44 24 08 e8 ee 8f f7 ff 48
[  814.351451] RSP: 002b:00007ffccfd77350 EFLAGS: 00000293 ORIG_RAX: 000000000000002e
[  814.351452] RAX: ffffffffffffffda RBX: 0000000000000001 RCX: 00007fe36f780ddd
[  814.351453] RDX: 0000000000000000 RSI: 00007ffccfd77390 RDI: 000000000000000d
[  814.351454] RBP: 000055e281605040 R08: 0000000000000000 R09: 0000000000000000
[  814.351455] R10: 0000000000000000 R11: 0000000000000293 R12: 000000000000007b
[  814.351456] R13: 00007ffccfd77500 R14: 00007ffccfd774fc R15: 0000000000000000
[  814.351457]  </TASK>
[  814.351458] ---[ end trace 0000000000000000 ]---
[  814.351475] rtw_8822bu 1-6:1.0: failed to do USB write, ret=-19
[  814.351477] rtw_8822bu 1-6:1.0: failed to send h2c packet
[  814.351478] rtw_8822bu 1-6:1.0: failed to do USB write, ret=-19
[  814.351479] rtw_8822bu 1-6:1.0: failed to send h2c packet
I already tried installing rtl88x2bu-cilynx-dkms-git but it didn't helped.
Fixed by following this Realtek RTL8812BU Wifi - How to blacklist the in kernel module
