Was running blender, web browsers and discord/teams during a class. PC froze, nothing was moving BUT I was able to hear the class for a bit, then cut out and then stuttered to death too. Other than that, everything else was just like a picture. Fixed by the power button.
Happened again just when running a browser and vim and again: twice today.
Not ram filling up- I've not been over 60% even with full work flow.
Each time my PC HAD been running longer than usual- maybe 9 hours max.
also, no idea what or how to get the system logs. its been about an hour since the last crash
using dragonized gaming edition.
inxi -Fxxxza output:
System: Kernel: 5.10.10-114-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=8385376e-058c-4190-b13c-0411b1ce92e4 rw [email protected] quiet
resume=UUID=25f83cb9-6cfa-4fc0-9ebb-5459b0de6e09 loglevel=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <filter> UEFI [Legacy]: American Megatrends v: 5220 date: 09/12/2019
CPU: Info: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 92312
Speed: 1375 MHz min/max: 1550/3850 MHz boost: disabled Core speeds (MHz):
1: 1375 2: 1375 3: 1375 4: 1374 5: 1375 6: 1375 7: 1375 8: 1375 9: 1374
10: 1374 11: 1374 12: 1374
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: Gigabyte driver: nvidia
v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 09:00.0 chip ID: 10de:1b83
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1449 s-dpi: 101 s-size: 967x364mm (38.1x14.3")
s-diag: 1033mm (40.7")
Monitor-1: DP-0 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-2: DVI-D-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.32.03
direct render: Yes
Audio: Device-1: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 09:00.1 chip ID: 10de:10f0
v: kernel bus ID: 0b:00.3 chip ID: 1022:1457
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo
bus ID: 1-3:2 chip ID: 046d:081b serial: <filter>
Sound Server: ALSA v: k5.10.10-114-tkg-bmq
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus ID: 03:00.0
chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: f000
bus ID: 08:00.0 chip ID: 8086:2723
IF: wlp8s0 state: up mac: <filter>
Drives: Local Storage: total: 1.25 TiB used: 35.41 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Transcend model: TS256GSSD370S
size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 6KB
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-08WN4A0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A02
ID-3: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SSD PLUS 120GB
size: 111.8 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 00RL
Partition: ID-1: / raw size: 94.61 GiB size: 94.61 GiB (100.00%) used: 35.41 GiB (37.4%)
fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-2: /home raw size: 94.61 GiB size: 94.61 GiB (100.00%)
used: 35.41 GiB (37.4%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
ID-3: /var/log raw size: 94.61 GiB size: 94.61 GiB (100.00%)
ID-4: /var/tmp raw size: 94.61 GiB size: 94.61 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.19 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdc2 maj-min: 8:34
ID-2: swap-2 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
ID-10: swap-10 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram8
ID-11: swap-11 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram9
ID-12: swap-12 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram10
ID-13: swap-13 type: zram size: 1.3 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram11
Sensors: System Temperatures: cpu: 34.4 C mobo: N/A gpu: nvidia temp: 57 C
Info: Processes: 326 Uptime: 20m wakeups: 0 Memory: 15.63 GiB used: 4.08 GiB (26.1%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages:
pacman: 1781 lib: 547 Shell: fish v: 3.1.2 default: Bash v: 5.1.4
running in: konsole inxi: 3.2.02
I edit your terminal output, please read wiki "Reporting bugs". Greetings SGS
