Hi,
i created a custom color scheme and i also changing the selection color from purple/fucsia(the default one) to yellow.
When i select the theme all look ok, but when i reboot all other color changes are still there except for the selection color, set again to the default one.
upgrading the system hasn't solved the problem.
I tried to look at the files under .local/share/color-schemes/<my_color_scheme>
but it seems to be ok.
I also searched on internet, with no success or better understanding of the problem.
Any idea?
System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=638c8e36-f133-4c54-a737-b6cd4c8a1540
systemd.unified_cgroup_hierarchy=1 loglevel=3 pci=noaer
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: HP product: HP Laptop 15-dw0xxx v: Type1ProductConfigId
Mobo: HP model: 85F0 v: 36.35 serial: <superuser required> UEFI: Insyde v: F.20
date: 11/25/2019
Battery: ID-1: BAT1 charge: 22.3 Wh (71.2%) condition: 31.3/41.9 Wh (74.6%) volts: 11.3 min: 11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Discharging
CPU: Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP arch: Kaby Lake note: check
family: 6 model-id: 8E (142) stepping: C (12) microcode: EA cache: L1: 256 KiB L2: 1024 KiB
L3: 6 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 976 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1000 2: 995 3: 1000 4: 1000 5: 1000
6: 1000 7: 1000 8: 1000
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:174e class-ID: 0302
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtl8821ce v: N/A modules: rtw88_8821ce,8821ce port: 3000 bus-ID: 03:00.0
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 6060
bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Drives: Local Storage: total: 476.94 GiB used: 50.38 GiB (10.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
rev: HPS0 temp: 33.9 C scheme: GPT
Partition: ID-1: / raw-size: 90 GiB size: 90 GiB (100.00%) used: 50.3 GiB (55.9%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 76.3 MiB (29.8%) fs: vfat
ID-3: /home raw-size: 90 GiB size: 90 GiB (100.00%) used: 50.3 GiB (55.9%) fs: btrfs
ID-4: /var/log raw-size: 90 GiB size: 90 GiB (100.00%) used: 50.3 GiB (55.9%) fs: btrfs
ID-5: /var/tmp raw-size: 90 GiB size: 90 GiB (100.00%) used: 50.3 GiB (55.9%) fs: btrfs
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 29.8 C pch: 43.0 C mobo: 27.8 C
Info: Processes: 258 Uptime: 4m wakeups: 1 Memory: 7.65 GiB used: 2.81 GiB (36.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: apt: 0 pacman: 1508
lib: 371 Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
My color scheme configuration file:
[ColorEffects:Disabled]
Color=56,56,56
ColorAmount=0
ColorEffect=0
ContrastAmount=0.65
ContrastEffect=1
IntensityAmount=0.1
IntensityEffect=2
[ColorEffects:Inactive]
ChangeSelectionColor=true
Color=112,111,110
ColorAmount=0.025
ColorEffect=2
ContrastAmount=0.1
ContrastEffect=2
Enable=false
IntensityAmount=0
IntensityEffect=0
[Colors:Button]
BackgroundAlternate=35,37,46
BackgroundNormal=33,36,44
DecorationFocus=255,212,38
DecorationHover=255,216,110
ForegroundActive=74,174,230
ForegroundInactive=92,98,108
ForegroundLink=255,216,110
ForegroundNegative=212,25,25
ForegroundNeutral=253,125,0
ForegroundNormal=255,255,255
ForegroundPositive=25,161,135
ForegroundVisited=92,98,108
[Colors:Selection]
BackgroundAlternate=43,98,192
BackgroundNormal=255,212,38
DecorationFocus=38,86,168
DecorationHover=38,86,168
ForegroundActive=0,0,0
ForegroundInactive=255,255,255
ForegroundLink=0,0,0
ForegroundNegative=191,23,23
ForegroundNormal=0,0,0
ForegroundPositive=94,189,171
ForegroundVisited=204,204,204
[Colors:Tooltip]
BackgroundAlternate=51,51,51
DecorationFocus=255,216,110
DecorationHover=43,98,192
[Colors:View]
[Colors:Window]
[General]
ColorScheme=Flat-Remix-Yellow-Dark
Name=Flat-Remix-Yellow-Dark
shadeSortColumn=true
[KDE]
contrast=4
[WM]
activeBackground=33,36,44
activeBlend=33,36,44
activeForeground=255,255,255
inactiveBackground=33,36,44
inactiveBlend=40,44,54
inactiveForeground=120,120,120
