Because you didn’t explain yourself well, and I don’t have much experience with bootloaders.
Of course, I want, simply I didn’t understand what to do with the output of your “tip command”.
Here we go again. I appreciate that someone like you help me, but if you don’t want to help, it is your issue.
When you serve, you do what a person order you without caring about the order. When you help, you do the best for helping the person. I told you if you wanted, not to doing it.
No, I didn't use Windows. I don't have it installed because I don't like it and I don't need it. If there are windows things inside my grub.d is grub-customizer's fault.
