Symlink or Path Issue? /usr/sbin/bash being called on makepkg
Kernel: 6.13.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=56d1f10b-cb16-46c0-9169-6bc3151b9b5d rw rootflags=subvol=@
intel_iommu=on iommu=pt transparent_hugepage=never quiet
resume=UUID=45d3cd5d-df18-46f9-8497-133a5a31ae08 loglevel=3 ibt=off
mitigations=off pcie_ports=native pci=nommconf
Type: Laptop System: Acer product: Predator PHN16-72 v: V1.14
Mobo: RPL model: EQE_RTX v: V1.14 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.14
date: 09/19/2024
ID-1: BAT1 charge: 91.3 Wh (100.0%) condition: 91.3/90.6 Wh (100.7%)
volts: 17.3 min: 15.4 model: LGC AP21A8T type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i9-14900HX bits: 64 type: MST AMCP arch: Raptor Lake
gen: core 14 level: v3 note: check built: 2022+ process: Intel 7 (10nm)
family: 6 model-id: 0xB7 (183) stepping: 1 microcode: 0x12B
Topology: cpus: 1x dies: 1 clusters: 12 cores: 24 threads: 32 mt: 8 tpc: 2
st: 16 smt: enabled cache: L1: 2.1 MiB desc: d-16x32 KiB, 8x48 KiB; i-8x32
KiB, 16x64 KiB L2: 32 MiB desc: 8x2 MiB, 4x4 MiB L3: 36 MiB desc: 1x36 MiB
Speed (MHz): avg: 1265 min/max: 800/5600:5800:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 1265 2: 1265 3: 1265
4: 1265 5: 1265 6: 1265 7: 1265 8: 1265 9: 1265 10: 1265 11: 1265 12: 1265
13: 1265 14: 1265 15: 1265 16: 1265 17: 1265 18: 1265 19: 1265 20: 1265
21: 1265 22: 1265 23: 1265 24: 1265 25: 1265 26: 1265 27: 1265 28: 1265
29: 1265 30: 1265 31: 1265 32: 1265 bogomips: 154828
Device-1: Intel Raptor Lake-S UHD Graphics vendor: Acer Incorporated ALI
built: 2020-21 ports: active: eDP-1 empty: none bus-ID: 0000:00:02.0
chip-ID: 8086:a788 class-ID: 0300
Device-2: NVIDIA AD106M [GeForce RTX 4070 Max-Q / Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 570.86.16
alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ ports: active: none
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:01:00.0 chip-ID: 10de:2860
Device-3: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate] vendor: Gigabyte
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 ports:
active: none off: DP-4 empty: DP-3, DP-5, HDMI-A-2, HDMI-A-3, HDMI-A-4
bus-ID: 0000:26:00.0 chip-ID: 10de:2216 class-ID: 0300
Device-4: Chicony ACER FHD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:2 chip-ID: 04f2:b799
Device-5: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.1.4:21
chip-ID: 045e:075d class-ID: 0102
Device-6: Lite-On HP Full-HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.2.4:20 chip-ID: 04ca:7078
Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 21.1.99
compositor: kwin_wayland driver: X: loaded: modesetting failed: nvidia
dri: iris gpu: i915,nvidia,nvidia-nvswitch d-rect: 7680x3040 display-ID: 0
Monitor-1: DP-4 pos: bottom-r model: Samsung LS49AG95 serial: <filter>
built: 2021 res: mode: 5120x1440 hz: 240 scale: 100% (1) dpi: 82 gamma: 1.2
size: 1193x336mm (46.97x13.23") diag: 1239mm (48.8") modes: max: 3840x1080
min: 640x480
Monitor-2: eDP-1 pos: primary,top-left model: BOE Display 0x0b17
built: 2022 res: mode: 2560x1600 hz: 240 scale: 135% (1.35) to: 1896x1185
dpi: 188 gamma: 1.2 size: 345x215mm (13.58x8.46") diag: 407mm (16")
ratio: 16:10 modes: 2560x1600
API: OpenGL v: 4.6.0 vendor: nvidia v: 570.86.16 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
memory: 9.77 GiB display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3080 driver: N/A device-ID: 10de:2216
Device-1: Intel Raptor Lake High Definition Audio
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:7a50 class-ID: 0401
Device-2: NVIDIA AD106M High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1 chip-ID: 10de:22bd class-ID: 0403
Device-3: NVIDIA GA102 High Definition Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 0000:26:00.1 chip-ID: 10de:1aef
Device-4: Microsoft LifeCam Cinema driver: snd-usb-audio,uvcvideo
Device-5: JMTek LLC. LCS USB Audio
lanes: 1 mode: 1.1 bus-ID: 1-9.2.1:17 chip-ID: 0c76:2018 class-ID: 0300
API: ALSA v: k6.13.1-zen1-1-zen status: kernel-api
Device-1: Intel Raptor Lake-S PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:7a70
Device-2: Realtek Killer E3000 2.5GbE vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 3000 bus-ID: 0000:43:00.0 chip-ID: 10ec:3000
IF: enp67s0 state: down mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9.1.3:16
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-4: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1:2 chip-ID: 0bda:8156
IF: enp35s0u1 state: up speed: 2500 Mbps duplex: full mac: <filter>
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0033
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 1.82 TiB used: 1.42 TiB (77.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 59.9 C
ID-1: / raw-size: 1.75 TiB size: 1.75 TiB (100.00%) used: 1.42 TiB (80.9%)
used: 604 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
used: 1.42 TiB (80.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.75 TiB size: 1.75 TiB (100.00%)
ID-1: swap-1 type: partition size: 69.01 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 32
System Temperatures: cpu: 49.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 5.1 GiB (16.4%)
Processes: 635 Power: uptime: 19m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.36 GiB services: org_kde_powerdevil,
Packages: 1884 pm: pacman pkgs: 1867 libs: 523 tools: octopi,paru
pm: flatpak pkgs: 17 Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13
Shell: garuda-inxi default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date:     2025-02-02
Last full system update: 2025-02-09 ↻
Failed units:            preload.service snapper-cleanup.service snapperd.service
I’ve been trying to install driverctl from AUR for experimentation with an eGPU setup.
Recently I’ve found a few applications referencing /usr/sbin for bash and other commands. I’ve posted the issue below but this doesn’t seem isolated to this application. Im starting to guess this might have to do with some mis-association of path between major linux distributions but I’m not sure if its just a borked setup on my behalf…
╰─λ makepkg -si
exec: Failed to execute process '/usr/bin/makepkg': The file specified the interpreter '/usr/sbin/bash', whichis not an executable command.
Is anyone familiar with this?, I see no reference on the installation to that path so I’m trying to figure out where it might have collected it from but I don’t know enough about the OS, would be good to get a kick in the right direction if anyone has the time?
Much appreciated.
Did you reboot since
Fix also
Yes, I think something has been majorly messed up. Its actually quite an old install but I keep it up to date. I launched from a garuda live usb, mounted the file system and appended the missing symlinks/ files from the core directories of the live usb to my screwed up installation. I think this has fixed most things. May just have to restore snapper from scratch.
