Hi guys, I want to switch from KDE to Sway.
Did anybody do something like that already? Should I do any preparations/after-install moves or just install Sway, remove KDE, use?
I just don't want to reinstall Garuda, just to try new DE
I strongly suggest playing with a live USB and maybe with a VM, if you have good specs.
And if you’re happy reinstall.
Moving from KDE to sway is a kind of multiple pike somersault which would fail 99.9% and anyway would make your system not supported…
