Hello again!
So i was wondering if swapping the monitor cables would help with some of my issues as i had read somewhere (long lost now), that this may be a fix for some of the KDE issues with main monitor. I wanted the arrangement to be consistent between my login screen and my desktop. I would log in, and my right monitor would act as though it were on the left and vice versa. Swapping them in the display settings on the desktop would not fix this at login. I think it did fix that.
HOWEVER
Now when i change settings for one monitor, it seems to apply to the other -- i see this in game with MangoHUD. The settings panel in KDE identifies each monitor correctly by name, but this afternoon i discovered that i was FPS capped in FFXIV at 60fps. I found it was the refresh rate setting in KDE, however, it was the other monitor set to 60Hz. First off, i have no idea why it suddenly changed. Second off, i have no idea why these settings aren't "port agnostic", or don't fix themselves at the time of swapping cables. It seems like a consistent issue based on what little googling I did to fix the initial problem that KDE multi monitor support is pretty shitty to begin with.
I know next to 0 about x11/xorg or display technology as it relates to desktop PCs at present. Is there a configuration file i can look in to make the monitor cable switch more permanent?
Both monitors are connected via display port.
"Main" monitor (right) - ASUSTEK Computer INC VG27A (DP-4)
"Alternate" monitor (left) - Dell Inc. S2715DG (DP-2)
╭─meredith@dragonfruit in ~
╰─λ garuda-inxi -Faz
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f6cccf9c-8580-435e-8f33-927e3e31bb2d rw rootflags=subvol=@
resume=UUID=2e9cba84-8fd3-4884-995e-6ac1c54716ad loglevel=3
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
Mobo: Gigabyte model: X570 AORUS ELITE v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F34
date: 06/10/2021
ID-1: hidpp_battery_0 charge: 49% condition: N/A volts: 3.8 min: N/A
Info: model: AMD Ryzen 9 3950X bits: 64 type: MT MCP arch: Zen 2
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3884 high: 4351 min/max: 2200/4761 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3703 2: 3571
3: 4264 4: 3569 5: 4057 6: 4180 7: 4164 8: 4351 9: 3686 10: 4008 11: 4149
12: 3622 13: 3776 14: 3597 15: 3587 16: 4155 17: 4042 18: 3792 19: 4166
20: 3536 21: 4094 22: 3802 23: 4052 24: 4286 25: 3549 26: 3592 27: 3595
28: 4221 29: 3863 30: 3438 31: 3593 32: 4245 bogomips: 223582
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 0a:00.0
chip-ID: 10de:1e84 class-ID: 0300
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 5119x1440 s-dpi: 107 s-size: 1215x342mm (47.8x13.5")
s-diag: 1262mm (49.7")
Monitor-1: DP-2 res: 2560x1440 dpi: 109 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
Monitor-2: DP-4 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2070 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: YUAN High-Tech Development vendor: Corsair Memory driver: N/A
bus-ID: 06:00.0 chip-ID: 12ab:0380 class-ID: 0480
Device-2: NVIDIA TU104 HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0a:00.1 chip-ID: 10de:10f8
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0c:00.4 chip-ID: 1022:1487
Device-4: Texas Instruments ATH-G1WL type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3.1.4:7
chip-ID: 0451:16ba class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
port: f000 bus-ID: 05:00.0 chip-ID: 8086:1539 class-ID: 0200
Local Storage: total: 4.57 TiB used: 499.66 GiB (10.7%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: A-Data model: SX6000PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: V9002s85
temp: 35.9 C scheme: GPT
model: WDS100T1XHE-00AFY0 size: 931.51 GiB block-size: physical: 512 B
rev: 614600WD temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
model: WD20EARX-00ZUDB0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A80 scheme: GPT
ID-1: / raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
used: 53.34 GiB (5.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
ID-4: /var/log raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.73 GiB size: 896.73 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.49 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.35 GiB used: 768 KiB (0.0%)
System Temperatures: cpu: 30.0 C mobo: 27.0 C gpu: nvidia temp: 45 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 24%
Processes: 554 Uptime: 1h 10m wakeups: 2 Memory: 31.35 GiB
used: 7.32 GiB (23.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 2025 lib: 539 Shell: fish
Garuda (2.5.4-2):
System install date: 2022-01-22
Last full system update: 2022-02-06
