Hi all
Has anyone been able to get Garuda linux installed and working on the surface laptop 2? I am able to run it from a usb but the wifi wont work. I want to make sure i can get it working as i am thinking to dual boot windows and linux.
Thanks
Hi all
Thanks
Seems you did not search the web.
I guess i will double check
Especially the mighty Arch wiki.
With the mentioned package you should be good to go
https://wiki.archlinux.org/title/Microsoft_Surface_Book_2#WiFi
According to that page, you might also need a specific kernel, but I don't know if Surface book 2 is the same as Surface laptop 2.
For the Marvell wifi chipset, I'm sure it should be the one in your model, which was mentioned in the garuda-inxi in another thread (info missing in yours).
