[suggestion] do not offer linux-tkg as default kernel to avoid potential system breakage
Since chaotic-aur repos are not synced with arch official and they have the bad habit to hop early into new kernel versions, despite extra modules being patched to support it. I am well aware of the problem but this could be an issue for the average user.
[suggestion number 2]: btrfs does not support grub parse yet, so you should remove "save last boot choice" entry from Garuda Boot Manager.
These issues are already being discussed.
Okay we will delay tkg-bmq kernel from next time
Until dkms works with it.
Yeah i likely forgot doing it
Thanks
We will detect if btrfs is used then hide that option
done
