Hi sir,
My name is Shourya. I am having some issues while installing the LXQT-KWIN flavour, when I tried to boot with USB It shows welcome to garuda and when I click on the boot option It shows the garuda Linux logo and after 2 or 3 minutes It says ( [ 0.095003] _ _common_interrupt : 1.55 No irq handler for vector) and stuck there.
What should I do I can't even boot It to live session, how should I install it, please solve this issue as soon as possible.
It doesn’t seem to be a Garuda problem. More like motherboard/BIOS vendor problem.
There is a discussion about it. Most reports say it is not stopping boot, but a few say they can’t.
You haven’t given any info about your system.
Maybe try to update your BIOS, if available.
In the linked discussion, some users suggest a couple of possible boot parameters, that may help, but not always.
Virtualization is probably conflicting, so it should better be off.
There is no magic to solve out sir.
I have suggested to try some boot kernel parameters (read the linked article) on the first ISO menu (grub menu).
If you can’t do that, then Archlinux/Garuda is probably not for you. That’s life…
