Stuck systemd screen
Hello,I’m trying to install Garuda, I'm stuck on this screen, what should I do?(I can’t upload ss)
Could you please better describe your problem? What do you see exactly?
By "trying to install" you mean you cannot boot the live USB you created?
If so, please provide the iso file name you downloaded and the method you used to burn the USB key.
On the contrary, if the issue occurs during or after "installation", so you can boot the live USB, please provide your garuda-inxi information from there.
Thank you Filo.I burn iso with ventoy(my laptop cant see boot usb some reason).Then I boot with nvidia choose.I stuck systemd screen,When I did some research, I thought there might be a problem with the iso, whereas I downloaded it today.That's why I wanted to try this place last. I don't know how to show you the output "garuda-inxi"I can't switch to live media. I can't take a screenshot either.
Thank you for the quick reply.
Please, no screenshots, just copy and paste the text from terminal
copy = Ctrl + Shift + C in terminal
or use garuda-assistant.
System Specs
I can't open the system, how do I send what I copied to you?
Again, please.
Use open source driver.
Check if the ISO download is corrupt.
I am sorry,doesnt match,Thank you for your patience, I downloaded another iso (gaming), I'll look into it now.
Many people have had problems with the Gaming ISO. Use the d460nized ISO.
And do what others have asked of you.
