Too bad.
Sorry, I'm not that expert on DKMS issues (I'm just a moderator, not a developer), so I hope someone will jump in soon with suggestions.
From my side, I'd suggest in the meanwhile to try (via TTY):
garuda-update
install the linux-lts kernel
and try to boot selecting that kernel in the grub (probably under advanced options).
provide garuda-inxi (from the system this time, not the USB)
For sure this is an option, if this is a recent install.
I see several users in the forum with your GPU (none with your exact laptop model).
Which ISO are you using? The latest official one is from 19-Oct-2022.
It happened in the past days that a couple of users unwillingly took a daily/development build and they were not functional.
I'm asking this because, again, that missing garuda-chroot is very strange.
Take the latest, e.g. from here.
I see in the USB inxi you booted fine with proprietary drivers, so go for that option! You'll need them in the end anyway...
hey.
i reinstalled my garuda can you tell me how i swtich my graphic driver safely and correctly? i already installed some apps i dont want to stuck on that initial ram disk page.
i apreciate it
i did and again i stuck on loading initial ramdisk. i used snap tool to restore my garuda. is there a way to install nvidia official driver and dont stuck on loading initial ramdisk?
I hope a Nvidia expert will jump in soon.
In the meanwhile, have you considered trying the linux-lts kernel and autoinstall the drivers again?
I remember not long ago of some Nvidia troubles with recent kernel version, but not being a Nvidia user I lost sight of those threads.
Last time i thought the problem might be my garuda installation. I reinstall my garuda and everything was fine untill installed nvidia driver and again stuck on loading initial ram disk hopefully this time i made a snapshot before installation and now i can restore my garuda. But problem still on. I cant use nvidia driver i really interested in garuda linux and mostly the design part but i cant fix this problem
Im going to download nvidia driver and install it manualy this time. Everytime i tried auto install got stuck on loading initial ram disk. I let you know if this works fine
