Strange issues in general (discussion and help):
Hello.
I tried looking this up already.
Basically: the theme with all the colors is quite the sensory overload issue for me. One might even say the colors are "offensive", being they're so loud and "burn my eyes to look at" if that makes sense.
I would like to use the Breeze icons, but many of them don't even show up properly, a few not at all in the menu.
Example: When Konsole is open, I see the icon. When it is closed and sitting in the dock, it's the blank page icon. After removing it from the dock, restarting the system, the issue appears to go away, but there's still no icon in the applications menu for it.
Also, on first login, the wallpaper is set to a smaller size and right clicking outside of where the wallpaper shows doesn't launch the expected menu. I have to change my resolution to something else then back again for it to look correct.
What have others done to overcome these issues?
EDIT: Added the inix output, cannot comment any more today, says I reached a limit or something.
inxi -Faz
λ inxi -Faz
Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b9d0afe6-93f2-4c3d-bae6-43707f4c0314 rw [email protected]
Type: Portable System: Alienware product: Alienware 14 v: A08
serial: <superuser required> Chassis: type: 8 v: A08
Mobo: Alienware model: 07MJ2Y v: A01 serial: <superuser required>
UEFI: Alienware v: A08 date: 02/25/2014
ID-1: BAT1 charge: 36.9 Wh (100.0%) condition: 36.9/71.0 Wh (52.0%)
volts: 12.3 min: 11.1 model: Simplo PABAS0241231 type: Li-ion
serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
status: Discharging
Info: model: Intel Core i7-4710MQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2495 high: 2496 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2495 2: 2495 3: 2495
4: 2495 5: 2495 6: 2496 7: 2495 8: 2495 bogomips: 39911
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK106M [GeForce GTX 765M] vendor: Dell driver: nvidia
v: 470.94 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:11e2
Device-3: Sunplus Innovation Laptop Integrated Webcam FHD type: USB
driver: uvcvideo bus-ID: 1-1.4:3 chip-ID: 1bcf:2b83 class-ID: 0e02
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 71
size: 690x390mm (27.2x15.4") diag: 793mm (31.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.3.3 compat-v: 3.0 direct render: Yes
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-3: NVIDIA GK106 HDMI Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e0b class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Qualcomm Atheros Killer E220x Gigabit Ethernet vendor: Dell
driver: alx v: kernel port: 3000 bus-ID: 08:00.0 chip-ID: 1969:e091
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter
vendor: Rivet Networks Killer Wireless-N 1202 Half-size Mini PCIe Card
driver: ath9k v: kernel bus-ID: 0a:00.0 chip-ID: 168c:0034 class-ID: 0280
IF: wlp10s0 state: up mac: <filter>
Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
v: 0.8 bus-ID: 2-1.5:5 chip-ID: 0cf3:3004 class-ID: e001
v: 3.0 port: 5060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1020.64 GiB used: 650.4 GiB (63.7%)
model: WD10JPVX-75JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: LITE-ON IT
model: DMT-80M6M-11 mSATA 80GB size: 74.53 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 10B
scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk
model: Cruzer Glide size: 14.59 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 74.51 GiB size: 74.51 GiB (100.00%)
used: 14.73 GiB (19.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 513 MiB size: 511.9 MiB (99.80%)
used: 38.7 MiB (7.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 736.67 GiB size: 724.11 GiB (98.29%)
used: 635.63 GiB (87.8%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 74.51 GiB size: 74.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 74.51 GiB size: 74.51 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 4.8 MiB (0.0%)
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 268 Uptime: 37m wakeups: 6 Memory: 15.51 GiB
used: 2.54 GiB (16.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1721 lib: 513 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
If inxi -Faz not works in your terminal konsole use live ISO and post it as text.
Do you use KDE in VM?
I know that Konsole specifically has a custom icon in dr460nized, you can
rm .local/share/applications/org.kde.konsole.desktop
to restore the default one. Not sure which other icons you're talking about, but surprisingly I've found Beautyline more comprehensive than Breeze.
That is a really strange problem with the screen resolution, I am not sure how to troubleshoot that... hopefully someone else has an idea
Thanks it worked but is there any ways to make garuda do this when icon theme is changed?
if not, then why use custom icon which causes trouble in the first place?
Mmm... pork chops... :cut_of_meat:
