Hello. I can't find a better category to suggest a new store for appimages (the suggestion topics are locked for some reason(?)), in any case I found AppImage Pool that might be handy to install appimages, and it might be added near the app for appimage settings.
root=UUID=c225b4b5-552f-4d1d-9325-180e06de7ec0 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 mitigations=off
sysrq_always_enabled=1 nowatchdog
Mobo: ASUSTeK model: PRIME B450M-A II v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3211
date: 08/10/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4198 high: 4200 min/max: 2200/5361 boost: enabled
scaling: driver: acpi-cpufreq governor: ondemand cores: 1: 4198 2: 4198
3: 4199 4: 4199 5: 4199 6: 4199 7: 4200 8: 4198 9: 4197 10: 4197 11: 4198
12: 4198 13: 4199 14: 4198 15: 4199 16: 4198 bogomips: 134389
vendor: PC Partner / Sapphire driver: amdgpu v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-2
empty: DP-1, DVI-D-1, HDMI-A-1, HDMI-A-2 bus-ID: 08:00.0
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
Monitor-1: DP-2 mapped: DisplayPort-1 model: Philips PHL 273V7
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 480 Graphics (polaris10 LLVM 13.0.1 DRM
3.44 5.17.1-zen1-1-zen)
v: 4.6 Mesa 22.0.1 direct render: Yes
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 0a:00.4 chip-ID: 1022:1487 class-ID: 0403
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 10ec:8168
Local Storage: total: 8.44 TiB used: 4.2 TiB (49.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM010-2EP102
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC43
ID-2: /dev/sdb maj-min: 8:16 vendor: Intenso model: SSD Sata III
type: SSD serial: <filter> rev: 9B0 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST3160815AS
size: 149.01 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: N/A serial: <filter> rev: A scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
model: Backup+ Hub BK size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: D781 scheme: GPT
ID-1: / raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
used: 86.28 GiB (77.4%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 563 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-4: /var/log raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.53 GiB size: 111.53 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.59 GiB used: 7.2 MiB (0.0%)
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 50.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 939
Processes: 464 Uptime: 1h 22m wakeups: 0 Memory: 15.59 GiB
used: 4.79 GiB (30.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 2170 pacman: 2149 lib: 542 flatpak: 21
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.1-1):
System install date: 2022-03-23
Last full system update: 2022-04-09
