Not at the computer right now rather pondering this question right now, you see I have put in a new SSD or HDD or whatever with a tb of space I need to wipe whatever was on it but then I want to use it of course!
What would be the best way of doing so? I have an internal storage of about 250 or something split between Linux and windows can I give storage to them directly? Should i move my installs? I want to understand how if one storage would fill up it would automatically just go to the tb
If you really need the Garuda input I can get it but it'll have to be a minute or two
Kernel: 5.18.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=0133cd8a-e39e-45cf-ab8c-6e1ee6565d1d rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
dm: SDDM Distro: Arch Linux
Type: Laptop System: Dell product: Inspiron 3593 v: N/A
Mobo: Dell model: 0TGVJN v: A00 serial: <superuser required> UEFI: Dell
v: 1.21.0 date: 05/11/2022
ID-1: BAT0 charge: 33.6 Wh (100.0%) condition: 33.6/42.0 Wh (79.9%)
volts: 13.1 min: 11.4 model: SWD-ATL3.618 DELL WJPC404 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
built: 2019-21 process: Intel 10nm family: 6 model-id: 0x7E (126)
stepping: 5 microcode: 0xB0
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2615 high: 3401 min/max: 400/3400 scaling:
driver: intel_pstate governor: performance cores: 1: 2521 2: 3401 3: 2748
4: 1791 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Dell driver: i915 v: kernel
arch: Gen11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:671e class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP1 model: AU Optronics 0x607a built: 2019
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
Sound Server-1: ALSA v: k5.18.6-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-3: PulseAudio v: 16.1 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: no
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 1.14 TiB used: 84.76 GiB (7.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data
model: IM2P33F3 NVMe 256GB size: 238.47 GiB block-size: physical: 512 B
rev: 91002105 temp: 32.9 C scheme: GPT
model: WD10JPVX-75JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A02 scheme: GPT
ID-1: / raw-size: 85.78 GiB size: 85.78 GiB (100.00%)
used: 84.7 GiB (98.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 57.4 MiB (22.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 85.78 GiB size: 85.78 GiB (100.00%)
ID-4: /var/log raw-size: 85.78 GiB size: 85.78 GiB (100.00%)
ID-5: /var/tmp raw-size: 85.78 GiB size: 85.78 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.54 GiB used: 4.4 MiB (0.1%) priority: 100
System Temperatures: cpu: 48.0 C mobo: 31.0 C
Fan Speeds (RPM): cpu: 0
Processes: 255 Uptime: 8h 22m wakeups: 3 Memory: 7.54 GiB
used: 3.35 GiB (44.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1920
lib: 528 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.3-2):
System install date: 2021-09-05
Last full system update: 2022-06-24
Snapshots: Timeshift (maybe)
Failed units: anbox-container-manager.service systemd-networkd-wait-online.service
