bwallx
1
The command garuda-inxl gives a command not found in Konsole
My issue: As a convert from windows I am used to double-clicking an icon to open it and find the single click method frustrating.
Can I adjust it to a double click please? I can not find any such setting anywhere.
dalto
2
If you are using dr4g0nized or kde, it is on the main page in system settings when you first open it up.
It is garuda-inxi
, not garuda-inxl
I also found this frustrating. Thanks.
bwallx
4
Thanks you for prompt reply
