Kernel: 5.15.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=007e6c2b-018b-40d5-bc8d-2bd7b4a51a26 rw rootflags=subvol=@
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: Apple product: MacBookPro11,5 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-06F11F11946D27C5
Mobo: Apple model: Mac-06F11F11946D27C5 v: MacBookPro11,5
serial: <superuser required> UEFI: Apple v: 428.60.3.0.0 date: 10/27/2021
ID-1: BAT0 charge: 78.6 Wh (99.6%) condition: 78.9/97.2 Wh (81.2%)
volts: 12.7 min: 11.3 model: SMP bq20z451 type: Li-ion serial: N/A
status: Charging cycles: 29
Info: model: Intel Core i7-4980HQ bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x46 (70) stepping: 1 microcode: 0x1C
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3122 high: 3862 min/max: 800/4000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2794 2: 3062 3: 3862
4: 3853 5: 3167 6: 2785 7: 2724 8: 2735 bogomips: 44695
Type: l1tf
Device-1: AMD Venus XT [Radeon HD 8870M / R9 M270X/M370X] vendor: Apple
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6821 class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: gnome-shell driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :1 screens: 1
Screen-1: 0 s-res: 2880x1800 s-dpi: 96 s-size: 762x476mm (30.0x18.7")
s-diag: 898mm (35.4")
Monitor-1: eDP res: 2880x1800 hz: 60 dpi: 221 size: 331x207mm (13.0x8.1")
diag: 390mm (15.4")
OpenGL: renderer: AMD VERDE (DRM 2.50.0 5.15.12-zen1-1-zen LLVM 13.0.0)
v: 4.5 Mesa 21.3.3 direct render: Yes
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Apple driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: facetimehd v: kernel
bus-ID: 05:00.0 chip-ID: 14e4:1570 class-ID: 0480
Sound Server-1: ALSA v: k5.15.12-zen1-1-zen running: yes
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel bus-ID: 04:00.0 chip-ID: 14e4:43ba
Device-1: Apple Bluetooth Host Controller type: USB
driver: btusb,hid-generic,usbhid bus-ID: 1-8:3 chip-ID: 05ac:8290
class-ID: fe01
address: <filter>
Local Storage: total: 931.84 GiB used: 28.85 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM1024G
size: 931.84 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: SA0Q scheme: GPT
ID-1: / raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
used: 28.85 GiB (3.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
ID-4: /var/log raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 931.54 GiB size: 931.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 22 MiB (0.1%) priority: 100
System Temperatures: cpu: 76.0 C pch: 59.5 C mobo: N/A gpu: radeon
temp: 75.0 C
Processes: 375 Uptime: 4h 40m wakeups: 2 Memory: 15.5 GiB
used: 3.83 GiB (24.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1569 lib: 487 Shell: Bash
v: 5.1.12 running-in: terminator inxi: 3.3.11
I am wondering why when I download anything from Steam my system runs so hot. I have noticed that my fans spin up and i run at over 105 degrees Fahrenheit. This does not appear to be a Garuda Linux issue, it appears to happen in multiple distros Arch or Debian. I am not sure if anyone can't fix the issue but I was just curious.
Thanks,
Jim
Note: As you will see in my inxi -Faz I am running Garuda on an older (mid 2015) MacBook Pro. I have replaced macOS, Linux is just far more superior.
