Hello, I have installed and updated Garuda. I can’t start any Steam games. The button turns blue and then green again. It is also the case that when I run “steam runtime” “steam native” is started. The updates that are then loaded are loaded too quickly. 1GB in 5 minutes with 110mbit! I have deleted the folders in Steam for Proton and co. But the updates go through so quickly again. The folders are created and the games don’t run. Also, after each start of steam I have to end and start the xboxdrv, via terminal.
Hello Garuda users.
Please post the terminal/konsole input and output as text (no pictures) from the following command:
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively, read the tips on the Garuda Wiki:
root=UUID=e0c36766-6b02-444a-938a-f32d6b4567d4 rw rootflags=subvol=@
quiet resume=UUID=04c10e1e-1647-469e-9828-011d2c17d2c0 loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 6203
date: 07/27/2023
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3595 high: 4450 min/max: 2200/4467 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3594 2: 3500
3: 3500 4: 4450 5: 3500 6: 3500 7: 3500 8: 3500 9: 3600 10: 3500 11: 3500
12: 3500 bogomips: 84004
Device-1: AMD Tahiti XT [Radeon HD 7970/8970 OEM / R9 280X] vendor: XFX Pine
driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DVI-I-1,HDMI-A-1
empty: DP-1,DP-2,DVI-D-1 bus-ID: 07:00.0 chip-ID: 1002:6798 class-ID: 0300
temp: 54.0 C
alternate: fbdev,vesa dri: radeonsi gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 3046x1050 s-dpi: 96 s-size: 805x277mm (31.69x10.91")
s-diag: 851mm (33.52")
Monitor-1: DVI-I-1 mapped: DVI-0 pos: left model: Samsung SyncMaster
serial: <filter> built: 2007 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-0 pos: primary,right model: Blaupunkt
built: 2019 res: 1366x768 hz: 60 dpi: 60 gamma: 1
size: 575x323mm (22.64x12.72") modes: max: 1366x768 min: 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.5 vendor: amd mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: TAHITI ( LLVM 16.0.6 DRM 2.50 6.6.1-zen1-1-zen)
device-ID: 1002:6798 memory: 2.93 GiB unified: no
API: Vulkan v: 1.3.269 layers: 13 device: 0 type: cpu name: llvmpipe
Device-1: AMD Tahiti HDMI Audio [Radeon HD 7870 XT / 7950/7970]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aaa0 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api with: aoss
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168
Device-2: Microsoft Xbox 360 Wireless Adapter driver: N/A type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 045e:0719
class-ID: ff00 serial: <filter>
IF-ID-1: enp1s0f0u1 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
driver: rndis_host v: kernel type: USB rev: 2.1 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-1:5 chip-ID: 04e8:6864 class-ID: 0a00 serial: <filter>
Local Storage: total: 931.52 GiB used: 77.76 GiB (8.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500420AS
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ACF050
tech: HDD rpm: 7200 serial: <filter> fw-rev: 2C scheme: MBR
ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
used: 77.76 GiB (17.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 63.2 MiB (0.8%) priority: 100
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 48.9 C mobo: N/A gpu: radeon temp: 54.0 C
Processes: 312 Uptime: 39m wakeups: 0 Memory: total: 8 GiB
available: 7.66 GiB used: 4.1 GiB (53.4%) Init: systemd v: 254
pm: pacman pkgs: 1790 libs: 527 tools: octopi,paru pm: flatpak pkgs: 0
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date: 2023-11-18
Last full system update: 2023-11-18
i have a good idea to solve the issue! i started download nobara linux, and i will reinstall it. steam and many other things worked out of the box. my steam games. but not zusi3. who cares. just one game. garuda was just trouble. beautiful trouble in dr460gonized version…
Very good idea, considering the effort made, or at least shown, to solve the issue.
