Hello, this is the first time im using garuda linux and i have a problem. Everytime i leave an app open when i shutdown the pc. It starts up when i turn it on. For example i had firefox opened last night, and when i booted today it opened again. I tried searching the settings and google but couldnt find anything. Any help would be great. Thanks
root=UUID=81879ee0-2bb9-4195-8919-c3c41e824603 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450 GAMING PLUS MAX (MS-7B86) v: 3.0
serial: UEFI: American Megatrends LLC. v: H.H0
date: 04/27/2023
Info: model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3519 high: 3650 min/max: N/A cores: 1: 3587 2: 3649
3: 3548 4: 3650 5: 3575 6: 3306 7: 3555 8: 3297 9: 3370 10: 3650 11: 3624
12: 3425 bogomips: 87599
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 26:00.0 chip-ID: 10de:1c03 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: Unknown-1 mapped: DP-0 res: 1920x1080 dpi: 82
size: 597x336mm (23.5x13.23") modes: 1920x1080
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.113.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.269 layers: 14 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1060 6GB driver: nvidia v: 535.113.01 device-ID: 10de:1c03
surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256
bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA GP106 High Definition Audio vendor: Gigabyte
bus-ID: 26:00.1 chip-ID: 10de:10f1 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Kingston driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.2:3
chip-ID: 0951:170b class-ID: 0300 serial:
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac:
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3
chip-ID: 0b05:17cb class-ID: fe01 serial:
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 2.04 TiB used: 20.83 GiB (1.0%)
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
tech: SSD serial: fw-rev: 0102 scheme: GPT
ID-1: / raw-size: 145.51 GiB size: 145.51 GiB (100.00%)
used: 20.83 GiB (14.3%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 145.51 GiB size: 145.51 GiB (100.00%)
ID-4: /var/log raw-size: 145.51 GiB size: 145.51 GiB (100.00%)
ID-5: /var/tmp raw-size: 145.51 GiB size: 145.51 GiB (100.00%)
System Temperatures: cpu: 59.4 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 31%
Processes: 334 Uptime: 1h 8m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 5.59 GiB (36.0%) Init: systemd v: 254
pm: pacman pkgs: 1947 libs: 563 tools: octopi,paru,yay pm: flatpak pkgs: 0
inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-10-28
Last full system update: 2023-10-29 ↻
Failed units: grub-btrfs-snapper.service
